softAp创建热点日志成功,搜索不到
bigux3000
softAp创建热点日志成功,搜索不到
Postby bigux3000 » Mon Jul 04, 2022 3:09 pm
芯片:esp32 s3 r8
idf版本:4.4
开发环境:vscode
问题描述:
softAp创建热点日志完成,使用手机和电脑都未找到热点
日志:
W (310) spi_flash: Detected size(16384k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (324) sleep: Configure to isolate all GPIO pins in sleep state
I (330) sleep: Enable automatic switching of GPIO sleep configuration
I (337) cpu_start: Starting scheduler on PRO CPU.
I (402) wifi softAP: ESP_WIFI_MODE_AP
I (402) pp: pp rom version: e7ae62f
I (402) net80211: net80211 rom version: e7ae62f
I (412) wifi:wifi driver task: 3fce5990, prio:23, stack:6656, core=0
I (412) system_api: Base MAC address is not set
I (412) system_api: read default base MAC address from EFUSE
I (442) wifi:wifi firmware version: 63017e0
I (442) wifi:wifi certification version: v7.0
I (442) wifi:config NVS flash: enabled
I (442) wifi:config nano formating: disabled
I (442) wifi:Init data frame dynamic rx buffer num: 32
I (452) wifi:Init management frame dynamic rx buffer num: 32
I (452) wifi:Init management short buffer num: 32
I (462) wifi:Init dynamic tx buffer num: 32
I (462) wifi:Init static tx FG buffer num: 2
I (462) wifi:Init static rx buffer size: 1600
I (472) wifi:Init static rx buffer num: 10
I (472) wifi:Init dynamic rx buffer num: 32
I (482) wifi_init: rx ba win: 6
I (482) wifi_init: tcpip mbox: 32
I (482) wifi_init: udp mbox: 6
I (492) wifi_init: tcp mbox: 6
I (492) wifi_init: tcp tx win: 5744
I (492) wifi_init: tcp rx win: 5744
I (502) wifi_init: tcp mss: 1440
I (502) wifi_init: WiFi IRAM OP enabled
I (512) wifi_init: WiFi RX IRAM OP enabled
I (522) phy_init: phy_version 501,94697a2,Apr 7 2022,20:49:08
I (622) wifi:mode : softAP (68:b6:b3:24:f0:d1)
I (622) wifi:Total power save buffer number: 16
I (622) wifi:Init max length of beacon: 752/752
I (632) wifi softAP: wifi_init_softap finished. SSID:abb1 password:12345678qw channel:6
LJY
Re: softAp创建热点日志成功,搜索不到
Postby LJY » Tue Jul 05, 2022 8:36 am
使用官方示例测试的吗? IDF/examples/wifi/getting_started/softAP
如果不是, 用官方示例是否可以搜索到?
bigux3000
Postby bigux3000 » Tue Jul 05, 2022 9:17 am
使用的官方例子,没改动情况下实验不行,后来只是修改了下ssid与密码,通道号再次尝试,依然不行
Users browsing this forum: Bing [Bot] and 0 guests
