Delete stored BLE Mesh configuration
elDi@mond
Postby elDi@mond » Mon Jul 11, 2022 5:20 am
To save network settings enough set parameter in menuconfig Store BLE Mesh configuration
Question is how to "manual", thru code, remove saved parameters?
Momin786
Contact:
Re: Delete stored BLE Mesh configuration
Postby Momin786 » Mon Jul 11, 2022 8:15 am
When you provision a node into BLE Mesh, provisioning information will be stored in permanent storage if persistence storage is enabled. Similarly, it will be removed when you remove the node from BLE Mesh using any provisioner app such as nRF Mesh, etc.
I create ESP32 tutorials and Projects using ESP-IDF https://esp32tutorials.com/
elDi@mond
Postby elDi@mond » Tue Jul 12, 2022 8:35 am
And if i need to hard-reset stored parametrs, by pushing button, what should be done?
Momin786
Contact:
Postby Momin786 » Tue Jul 12, 2022 11:51 am
I am not sure but you can refer to these APIs to see which API to call to remove persistence storage information:
https://docs.espressif.com/projects/esp ... -mesh.html
But other than this you will also need to implement a logic which will inform a provisioner that the information related to this node should be removed from the mesh network and it should not be part of the mesh network anymore.
elDi@mond
Postby elDi@mond » Fri Jul 15, 2022 10:21 am
I found it! :D
esp_ble_mesh_provisioner_direct_erase_settings()
Users browsing this forum: Bing [Bot], Bytespider, Semrush [Bot] and 2 guests
