Definition "extern pcnt_dev_t PCNT" + ISR
onpa_esp32
Postby onpa_esp32 » Fri Sep 01, 2017 3:26 pm
Folks,
I'm playing with Pulse Counter in ESP32.
I'm able count pulses now, but can't invoke ISR. Resp. - I'm able to define ISR, but program probably get-lock in the ISR and never release it.
I'm trying to find the root-cause. Maybe, the flag for finishing interrupt is not cleared.
So, I would like to clear the flag manually, infortunatelly can't compile foloving code :
(if I remove registration of ISR routine "pcnt_example_intr_handler", code works properly. After registration ISR and fulfillling condition - the ISR is executed but the program is completely frozen :( )
#include "driver/pcnt.h"
/* LED pin */
byte ledPin = 12;
/* pin that is attached to interrupt */
byte interruptPin = 14;
/* hold the state of LED when toggling */
byte pulsePin = 13;
int16_t flow0Counter = 45;
volatile byte state = LOW;
#define PCNT_TEST_UNIT     PCNT_UNIT_0
#define PCNT_H_LIM_VAL     10
#define PCNT_L_LIM_VAL     -10
#define PCNT_THRESH1_VAL   5
#define PCNT_THRESH0_VAL   -5
  pinMode(ledPin, OUTPUT);
  /* set the interrupt pin as input pullup*/
  pinMode(interruptPin, INPUT_PULLUP);
  /* attach interrupt to the pin
  function blink will be invoked when interrupt occurs
  interrupt occurs whenever the pin change value */
  attachInterrupt(digitalPinToInterrupt(interruptPin), blink, CHANGE);
  pinMode(pulsePin,INPUT_PULLUP);
  Serial.println("");
  initPcnt();
  Serial.println("Smycka");
  readPcntCounter_0();
  delay(1000);
/* interrupt function toggle the LED */
/* fungovalo do cca 300kHz vstupního kmitočtu */
void blink() {
  state = !state;
  digitalWrite(ledPin, state);
/* interrupt function for PCNT */
void IRAM_ATTR pcnt_example_intr_handler(void* arg) {
  uint32_t intr_status;
  intr_status = PCNT.int_st.val;
  int i;
  for(i = 0; i < PCNT_UNIT_MAX; i++) {
      if(intr_status & (BIT(i))) {
          PCNT.int_clr.val = BIT(i);
//initialize counter for flow0
void initPcnt() {
  esp_err_t error;
  Serial.println("Inicializace pulse totalizeru");
  pcnt_config_t pcnt_config = {
    pulsePin, // Pulse input gpio_num, if you want to use gpio16, pulse_gpio_num = 16, a negative value will be ignored
    PCNT_PIN_NOT_USED, // Control signal input gpio_num, a negative value will be ignored
    PCNT_MODE_KEEP, // PCNT low control mode
    PCNT_MODE_KEEP, // PCNT high control mode
    PCNT_COUNT_INC, // PCNT positive edge count mode
    PCNT_COUNT_DIS, // PCNT negative edge count mode
    PCNT_H_LIM_VAL, // Maximum counter value
    PCNT_L_LIM_VAL, // Minimum counter value
    PCNT_TEST_UNIT, // PCNT unit number
    PCNT_CHANNEL_0, // the PCNT channel
  if(pcnt_unit_config(&pcnt_config) == ESP_OK) //init unit
    Serial.println("Config Unit_0 = ESP_OK");
  /*Configure input filter value*/
  pcnt_set_filter_value(PCNT_TEST_UNIT, 100);
  /*Enable input filter*/
  pcnt_filter_enable(PCNT_TEST_UNIT);
  /*Set value for watch point thresh1*/
  pcnt_set_event_value(PCNT_TEST_UNIT, PCNT_EVT_THRES_1, PCNT_THRESH1_VAL);
  /*Enable watch point event of thresh1*/
  //pcnt_event_enable(PCNT_TEST_UNIT, PCNT_EVT_THRES_1);
  /*Set value for watch point thresh0*/
  pcnt_set_event_value(PCNT_TEST_UNIT, PCNT_EVT_THRES_0, PCNT_THRESH0_VAL);
  /*Enable watch point event of thresh0*/
  //pcnt_event_enable(PCNT_TEST_UNIT, PCNT_EVT_THRES_0);
  pcnt_event_disable(PCNT_TEST_UNIT, PCNT_EVT_THRES_0);
  /*Enable watch point event of h_lim*/
  //pcnt_event_enable(PCNT_TEST_UNIT, PCNT_EVT_H_LIM);
  pcnt_event_disable(PCNT_TEST_UNIT, PCNT_EVT_H_LIM);
  /*Enable watch point event of l_lim*/
  //pcnt_event_enable(PCNT_TEST_UNIT, PCNT_EVT_L_LIM);
  pcnt_event_disable(PCNT_TEST_UNIT, PCNT_EVT_L_LIM);
  /*Enable watch point event of zero*/
  //pcnt_event_enable(PCNT_TEST_UNIT, PCNT_EVT_ZERO);
  /*Pause counter*/
  pcnt_counter_pause(PCNT_TEST_UNIT);
  /*Reset counter value*/
  pcnt_counter_clear(PCNT_TEST_UNIT);
  /*Register ISR handler*/
  pcnt_isr_register(pcnt_example_intr_handler, NULL, 0, NULL);
  /*Enable interrupt for PCNT unit*/
  pcnt_intr_enable(PCNT_TEST_UNIT);
  /*Resume counting*/
  pcnt_counter_resume(PCNT_TEST_UNIT);
void readPcntCounter_0() {
  if(pcnt_get_counter_value(PCNT_UNIT_0, &flow0Counter) == ESP_OK)
  Serial.println("Read pcnt unit 0");
  delay(10);
  Serial.print("flow0Counts = ");
  Serial.println(flow0Counter);
Why PCNT variable is not visible ?
Result of compilation :
platformio run
Collected 14 compatible libraries
Looking for dependencies...
No dependencies
Compiling .pioenvs\lolin32\src\Interrupt.ino.o
In file included from C:\users\fft\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\driver/drive
r/pcnt.h:12:0,
from D:/Projects/ESP32/Interrupt2/src/Interrupt.ino:1:
C:\users\fft\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\soc/soc/pcnt_struct.h:171:19: error: 'pcnt_dev_t PCNT', declared using anonymous type, is used but never defined [-fpermissive]
extern pcnt_dev_t PCNT;
C:\users\fft\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\soc/soc/pcnt_struct.h:170:3: note:
'typedef volatile struct<anonymous> pcnt_dev_t' does not refer to the unqualified type, so it is not used for linkage
} pcnt_dev_t;
*** [.pioenvs\lolin32\src\Interrupt.ino.o] Error 1
What do you think about it ? Any ideas ?
Thanks,
Ondrej
Re: Definition "extern pcnt_dev_t PCNT" + ISR
Postby Sprite » Sat Sep 02, 2017 2:59 am
Do you happen to know which version of ESP-IDF you are running?
ESP_igrr
Postby ESP_igrr » Sat Sep 02, 2017 3:09 pm
Placing #include "soc/pcnt_struct.h" within extern "C" { ... } block should fix the issue. We are adding header guards for all components, so in the long run this workaround will not be needed.
onpa_esp32
Postby onpa_esp32 » Mon Sep 04, 2017 1:29 pm
Thanks. It helped.
extern "C" {
solved the issue and Pulse counter is working now.
  int i;
  state = !state;
  /* smažeme příznak přerušení */
Just for info, inside ISR is necessary clear Interrupt Flag - "PCNT.int_st.val" ? Probably yes, without mentioned code inside ISR is micro frozen...
I saw example with calling "attachInterrupt" function, ISR function in this case doesn't use clearing flag mechanism...
Ondrej
filo_gr
Postby filo_gr » Fri Jan 06, 2023 6:01 pm
This helped me too, without extern "C". ESP-IDF v4.4.0 :D
Filippo
Akuji!
Postby Akuji! » Sun Feb 04, 2024 2:18 am
Thanks! Now I'm getting an undefined error with "PCNT_STATUS_THRES0_M" and "PCNT_STATUS_THRES1_M" variables :shock:
Is there any other file I should import?
Thanks!
Users browsing this forum: PerplexityBot, Qwantbot and 3 guests
