uart_write_bytes or uart_tx_chars crashing
Posted: Sat Sep 02, 2017 9:44 am
Hi
I am trying to write a simple code where the UART1 data gets sent to a TCP server. However, I am having an issue writing anything to UART1, or UART0 for that matter. The code works just fine if I don't write anything to UART1, just read. However, I can't read anything from UART0.
Basically invoking uart_write_bytes or uart_tx_chars to UART1 causes a reset, some watchdog timer.
Can anyone help with this?
Thanks in advance
Console log:
My code:
Thanks in advance
Console log:
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0010,len:4
load:0x3fff0014,len:4348
load:0x40078000,len:0
load:0x40078000,len:11392
entry 0x40078cb8
I (931) cpu_start: Pro cpu up.
I (931) cpu_start: Single core mode
I (934) heap_init: Initializing. RAM available for dynamic allocation:
I (967) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (1023) heap_init: At 3FFC7AC8 len 00018538 (97 KiB): DRAM
I (1080) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (1140) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1200) heap_init: At 40093310 len 0000CCF0 (51 KiB): IRAM
I (1258) cpu_start: Pro cpu start user code
I (1418) cpu_start: Starting scheduler on PRO CPU.
I (1475) wifi: wifi firmware version: 8bd4b47
I (1475) wifi: config NVS flash: enabled
I (1475) wifi: config nano formating: disabled
I (1476) system_api: Base MAC address is not set, read default base MAC address from BLK0 of E
I (1486) system_api: Base MAC address is not set, read default base MAC address from BLK0 of E
I (1500) wifi: Init dynamic tx buffer num: 32
I (1500) wifi: Init data frame dynamic rx buffer num: 32
I (1504) wifi: Init management frame dynamic rx buffer num: 32
I (1510) wifi: wifi driver task: 3ffcf370, prio:23, stack:4096
I (1516) wifi: Init static rx buffer num: 10
I (1520) wifi: Init dynamic rx buffer num: 32
I (1524) wifi: Init rx ampdu len mblock:7
I (1527) wifi: Init lldesc rx ampdu entry mblock:4
I (1532) wifi: wifi power manager task: 0x3ffd47e0 prio: 21 stack: 2560
I (1555) phy: phy_version: 357.0, a6bf95b, Jul 25 2017, 12:28:06, 0, 0
I (1556) wifi: Init Ampdu: 1 tx baw=6 rx baw=6
I (1556) wifi: mode : sta (24:0a:c4:81:eb:58)
ets Jun 8 2016 00:22:57
rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x40078cb8
W (266) boot: PRO CPU has been reset by WDT.
W (266) boot: WDT reset info: PRO CPU PC=0x40086e8e
W (267) boot: WDT reset info: APP CPU PC=0x16bc92c1
I (1210) cpu_start: Pro cpu up.
I (1211) cpu_start: Single core mode
I (1214) heap_init: Initializing. RAM available for dynamic allocation:
I (1249) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (1305) heap_init: At 3FFC7AC8 len 00018538 (97 KiB): DRAM
I (1363) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (1422) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1483) heap_init: At 40093310 len 0000CCF0 (51 KiB): IRAM
I (1540) cpu_start: Pro cpu start user code
I (1700) cpu_start: Starting scheduler on PRO CPU.
I (1758) wifi: wifi firmware version: 8bd4b47
I (1758) wifi: config NVS flash: enabled
I (1758) wifi: config nano formating: disabled
I (1759) system_api: Base MAC address is not set, read default base MAC address from BLK0 of E
I (1769) system_api: Base MAC address is not set, read default base MAC address from BLK0 of E
I (1783) wifi: Init dynamic tx buffer num: 32
I (1783) wifi: Init data frame dynamic rx buffer num: 32
I (1787) wifi: Init management frame dynamic rx buffer num: 32
I (1793) wifi: wifi driver task: 3ffcf370, prio:23, stack:4096
I (1799) wifi: Init static rx buffer num: 10
I (1803) wifi: Init dynamic rx buffer num: 32
I (1807) wifi: Init rx ampdu len mblock:7
I (1810) wifi: Init lldesc rx ampdu entry mblock:4
I (1815) wifi: wifi power manager task: 0x3ffd47e0 prio: 21 stack: 2560
I (1839) phy: phy_version: 357.0, a6bf95b, Jul 25 2017, 12:28:06, 0, 0
I (1840) wifi: Init Ampdu: 1 tx baw=6 rx baw=6
I (1840) wifi: mode : sta (24:0a:c4:81:eb:58)
ets Jun 8 2016 00:22:57Code: Select all
#include "esp_wifi.h"
#include "esp_system.h"
#include "esp_event.h"
#include "esp_event_loop.h"
#include "nvs_flash.h"
#include "driver/gpio.h"
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "freertos/task.h"
#include "driver/uart.h"
#include "freertos/queue.h"
#include "esp_log.h"
#include "soc/uart_struct.h"
#include "sdkconfig.h"
#include "lwip/err.h"
#include "lwip/sockets.h"
#include "lwip/sys.h"
#include "lwip/netdb.h"
#include "lwip/dns.h"
//#define ECHO_TEST_TXD (4)
//#define ECHO_TEST_RXD (5)
#define ECHO_TEST_TXD (16)
#define ECHO_TEST_RXD (17)
#define ECHO_TEST_RTS (18)
#define ECHO_TEST_CTS (19)
#define BUF_SIZE (1024)
char temp[40];
char temp1[BUF_SIZE];
esp_err_t event_handler(void *ctx, system_event_t *event)
return ESP_OK;
//an example of echo test with hardware flow control on UART1
void sendToServer() {
int sockfd, n;
struct sockaddr_in serv_addr;
struct hostent *server;
sockfd = socket(AF_INET, SOCK_STREAM, 0);
server = gethostbyname("192.168.1.24");
bzero((char *) &serv_addr, sizeof(serv_addr));
serv_addr.sin_family = AF_INET;
bcopy((char *)server->h_addr, (char *)&serv_addr.sin_addr.s_addr, server->h_length);
serv_addr.sin_port = htons(43333);
if (connect(sockfd,(struct sockaddr *) &serv_addr,sizeof(serv_addr)) < 0)
printf("ERROR connecting");
n = write(sockfd, temp1, strlen(temp1));
shutdown(sockfd, SHUT_RDWR);
close(sockfd);
static void echo_task()
const int uart_num = UART_NUM_1;
//const int uart_num = UART_NUM_2;
uart_config_t uart_config = {
.baud_rate = 115200,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_DISABLE,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
.rx_flow_ctrl_thresh = 122,
//Configure UART1 parameters
uart_param_config(uart_num, &uart_config);
//Set UART1 pins(TX: IO4, RX: I05, RTS: IO18, CTS: IO19)
uart_set_pin(uart_num, GPIO_NUM_9, GPIO_NUM_10, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
//Install UART driver (we don't need an event queue here)
//In this example we don't even use a buffer for sending data.
uart_driver_install(uart_num, BUF_SIZE * 2, 0, 0, NULL, 0);
uint8_t* data = (uint8_t*) malloc(BUF_SIZE);
uart_write_bytes(uart_num, (const char*) "Ready", strlen("Ready!"));
//uart_tx_chars(uart_num, "\n\rReady!\n\r", strlen("\n\rReady!\n\r"));
bzero(temp1, BUF_SIZE);
while(1) {
//Read data from UART
int len = uart_read_bytes(uart_num, data, BUF_SIZE, 20 / portTICK_RATE_MS);
//uart_flush(uart_num);
bzero(temp, 40);
memcpy(temp, data, len);
//Write data back to UART
if (len >= 1)
if (temp[0] != 0x0D )
strcat(temp1, temp);
else {
printf("Sending to server: %s \n\r", temp1);
sendToServer();
//uart_write_bytes(uart_num, (const char*) data, len);
void app_main(void)
nvs_flash_init();
tcpip_adapter_init();
ESP_ERROR_CHECK( esp_event_loop_init(event_handler, NULL) );
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK( esp_wifi_init(&cfg) );
ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
wifi_config_t sta_config = {
.sta = {
.ssid = "",
.password = "",
.bssid_set = false
ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_STA, &sta_config) );
ESP_ERROR_CHECK( esp_wifi_start() );
ESP_ERROR_CHECK( esp_wifi_connect() );
echo_task();
