Hi, This is may first Time using ESP RM
it work's well but every time when i lost WIFI connection i need to reboot My ESP
1. is there a way to activate Auto connect
2. How can i activate Local control using Arduino IDE
Can't connect to Wifi automaticly Unless i reboot ESP32
sanketwadekar
- Espressif staff
Re: Can't connect to Wifi automaticly Unless i reboot ESP32
To auto connect to WiFi, you can create an event handler function like this.
And then in setup() function of Arduino, add the following statement.
I have tried and tested this on ESP32 using Arduino 1.8.3
void WiFiEvent(WiFiEvent_t event, arduino_event_info_t info){
switch(event){
case ARDUINO_EVENT_WIFI_STA_DISCONNECTED:
Serial.println("Disconnected from station, attempting reconnection");
WiFi.reconnect();
default:
}Code: Select all
WiFi.onEvent(WiFiEvent);Re: Can't connect to Wifi automaticly Unless i reboot ESP32
Yes it's work for me thank you
what about activate local control using Arduino IDE is that option available
i see it here but can't understand who can i use it using Arduino IDE
https://rainmaker.espressif.com/docs/local-control.html
