BLE server, need the RSSI of its clients to perform action.
Kikolobo
Postby Kikolobo » Mon Jul 25, 2022 7:45 pm
Hello all,
I am working on an application that uses BLE as a server in an ESP32. Clients connect to it and send a code to open a door. This works fine but I need to do this when the RSSI of the device goes above a certain threshold or power to make sure the Client device is close to the chip server.
I implemented this using the Arduino BLE abstraction of ESP32 using the server mechanism.
Is there a way to retrieve the RSSI value when a characteristic is written to? Like in a server or characteristic callback ?
Ir a way to retrieve the connected clients to the server so we can read or get their respective RSSI VALUÉ?
Any help would be appreciated.
Kikolobo
Re: BLE server, need the RSSI of its clients to perform action.
Postby Kikolobo » Wed Jul 27, 2022 5:39 pm
Anyone?
Should I switch to client instead of server ? But I need multiple connections.
Any help welcomed.
Kikolobo
Postby Kikolobo » Sun Aug 07, 2022 10:22 pm
Just in case someone needs to do this. The way I Solved it is by doing the following:
1) Right after:
BLEDevice::init("DeviceName");
Add:
BLEDevice::setCustomGapHandler(my_gap_event_handler);
Where : my_gap_event_handler is a callback function that looks like this:
static void my_gap_event_handler(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t* param) {
In here, you check the param to extract the RSSI :
  String devAddress = String(*param->read_rssi_cmpl.remote_addr);
  int8_t rssi = param->read_rssi_cmpl.rssi;
In order to request the RSSi you need to ask for it somewhere, in my case, I do this in the BLECharacteristicCallbacks function OnWrite because it fits my application, but this can be done anywhere you have access to the remote device address. You just call:
esp_err_t rc = ::esp_ble_gap_read_rssi(param->read.bda);
I hope this helps someone!
aXXo250
Postby aXXo250 » Tue Aug 27, 2024 11:54 pm
Thanks for this, ive been looking for exactly this online for a while now. :idea:
oh btw did you use the server example in the end?
and what security did you use?
i see it was a while ago u posted this so hopefully your still active, and even better have progressed with it.
Thanks again
Users browsing this forum: Bing [Bot], PerplexityBot, PetalBot and 3 guests
