how should I print the http payload (response)
eliasorggro
Postby eliasorggro » Thu Jul 28, 2022 8:30 am
I have this rest api here : https://retoolapi.dev/XB1y0H/data
I want to make a persistence connection by http_client to get data from it with much less delay .
/* ESP HTTP Client Example
#include <string.h>
#include <stdlib.h>
#include "freertos/task.h"
#include "esp_log.h"
#include "esp_system.h"
#include "nvs_flash.h"
#include "esp_event.h"
#include "esp_netif.h"
#include "protocol_examples_common.h"
#include "esp_tls.h"
#include "esp_crt_bundle.h"
#include "sdkconfig.h"
#include "esp_http_client.h"
#define MAX_HTTP_RECV_BUFFER 512
#define MAX_HTTP_OUTPUT_BUFFER 2048
static const char *TAG = "HTTP_CLIENT";
/* Root cert for howsmyssl.com, taken from howsmyssl_com_root_cert.pem
   The PEM file was extracted from the output of this command:
   openssl s_client -showcerts -connect www.howsmyssl.com:443 </dev/null
   The CA root cert is the last cert given in the chain of certs.
   To embed it in the app binary, the PEM file is named
   in the component.mk COMPONENT_EMBED_TXTFILES variable.
extern const char howsmyssl_com_root_cert_pem_start[] asm("_binary_howsmyssl_com_root_cert_pem_start");
extern const char howsmyssl_com_root_cert_pem_end[]   asm("_binary_howsmyssl_com_root_cert_pem_end");
extern const char postman_root_cert_pem_start[] asm("_binary_postman_root_cert_pem_start");
extern const char postman_root_cert_pem_end[]   asm("_binary_postman_root_cert_pem_end");
esp_err_t _http_event_handler(esp_http_client_event_t *evt)
    static char *output_buffer;  // Buffer to store response of http request from event handler
    static int output_len;       // Stores number of bytes read
    switch(evt->event_id) {
        case HTTP_EVENT_ERROR:
            ESP_LOGD(TAG, "HTTP_EVENT_ERROR");
        case HTTP_EVENT_ON_CONNECTED:
            ESP_LOGD(TAG, "HTTP_EVENT_ON_CONNECTED");
        case HTTP_EVENT_HEADER_SENT:
            ESP_LOGD(TAG, "HTTP_EVENT_HEADER_SENT");
        case HTTP_EVENT_ON_HEADER:
            ESP_LOGD(TAG, "HTTP_EVENT_ON_HEADER, key=%s, value=%s", evt->header_key, evt->header_value);
        case HTTP_EVENT_ON_DATA:
            ESP_LOGD(TAG, "HTTP_EVENT_ON_DATA, len=%d", evt->data_len);
             *  Check for chunked encoding is added as the URL for chunked encoding used in this example returns binary data.
             *  However, event handler can also be used in case chunked encoding is used.
            if (!esp_http_client_is_chunked_response(evt->client)) {
                // If user_data buffer is configured, copy the response into the buffer
                if (evt->user_data) {
                    memcpy(evt->user_data + output_len, evt->data, evt->data_len);
                    if (output_buffer == NULL) {
                        output_buffer = (char *) malloc(esp_http_client_get_content_length(evt->client));
                        output_len = 0;
                            ESP_LOGE(TAG, "Failed to allocate memory for output buffer");
                            return ESP_FAIL;
                    memcpy(output_buffer + output_len, evt->data, evt->data_len);
                output_len += evt->data_len;
        case HTTP_EVENT_ON_FINISH:
            ESP_LOGD(TAG, "HTTP_EVENT_ON_FINISH");
            if (output_buffer != NULL) {
                // Response is accumulated in output_buffer. Uncomment the below line to print the accumulated response
                // ESP_LOG_BUFFER_HEX(TAG, output_buffer, output_len);
                free(output_buffer);
                output_buffer = NULL;
            output_len = 0;
        case HTTP_EVENT_DISCONNECTED:
            ESP_LOGI(TAG, "HTTP_EVENT_DISCONNECTED");
            int mbedtls_err = 0;
            esp_err_t err = esp_tls_get_and_clear_last_error(evt->data, &mbedtls_err, NULL);
            if (err != 0) {
                ESP_LOGI(TAG, "Last esp error code: 0x%x", err);
                ESP_LOGI(TAG, "Last mbedtls failure: 0x%x", mbedtls_err);
            output_len = 0;
    return ESP_OK;
static void https_with_url(void)
    esp_http_client_config_t config = {
        .url = "https://retoolapi.dev/XB1y0H/data/",
        .event_handler = _http_event_handler,
        .crt_bundle_attach = esp_crt_bundle_attach,
    esp_err_t err = esp_http_client_perform(client);
    if (err == ESP_OK) {
        ESP_LOGI(TAG, "HTTPS Status = %d, content_length = %d",
                esp_http_client_get_status_code(client),
                esp_http_client_get_content_length(client));
        ESP_LOGE(TAG, "Error perform http request %s", esp_err_to_name(err));
    esp_http_client_cleanup(client);
static void http_test_task(void *pvParameters)
   https_with_url();
    ESP_LOGI(TAG, "Finish http example");
    vTaskDelete(NULL);
void app_main(void)
    ESP_ERROR_CHECK(ret);
    /* This helper function configures Wi-Fi or Ethernet, as selected in menuconfig.
     * Read "Establishing Wi-Fi or Ethernet Connection" section in
     * examples/protocols/README.md for more information about this function.
    ESP_ERROR_CHECK(example_connect());
    ESP_LOGI(TAG, "Connected to AP, begin http example");
    xTaskCreate(&http_test_task, "http_test_task", 8192, NULL, 5, NULL);
when it's uploaded , I got :
I (13630) example_connect: Connected to example_connect: sta
I (13640) example_connect: - IPv4 address: 192.168.43.25
I (13640) example_connect: - IPv6 address: fe80:0000:0000:0000:ee94:cbff:fe6f:5374, type: ESP_IP6_ADDR_IS_LINK_LOCAL
I (13660) HTTP_CLIENT: Connected to AP, begin http example
I (15330) esp-x509-crt-bundle: Certificate validated
I (17630) HTTP_CLIENT: HTTPS Status = 200, content_length = 59
I (17640) HTTP_CLIENT: HTTP_EVENT_DISCONNECTED
I (17640) HTTP_CLIENT: Finish http example
but I want to print the HTTP response ( the json data )
what should I do ? :(
sanketwadekar
Re: how should I print the http payload (response)
Postby sanketwadekar » Mon Aug 01, 2022 11:43 am
In your code, the response data is stored in output_buffer. If you want to print the response data, you can do that by calling print functions inside the HTTP_EVENT_ON_FINISH event handler case.
Users browsing this forum: Bing [Bot], Bytespider, Google [Bot], PerplexityBot, Qwantbot, Semrush [Bot] and 1 guest
