Being a simple soul all I want to do is use wroom flash like I use EEPROM. Can someone please provide a toddlers guide to ESP32flash in the arduino environment. I have looked at preferences.h and the two examples provided but they are for single entities, a counter and a string, not a set of data, the '"blob" example link does not operate.
My limited understanding from these examples is that you define a partition under begin() and that each memory location is essentially "pointed at" by a const char descriptor rather than an memory location as would be the case with an EEprom
So I used the following to assign a large amount of variables and read them back
To Write..................
#include <Preferences.h>
Preferences preferences;
preferences.clear();
preferences.begin("my-app", false);
for (int i=0;i<1000;i++)
String loc=String(i);
preferences.putUInt(loc.c_str(),i);
// Close the Preferences
preferences.end();
void loop() {}
I shut the power to the wroom, repowered and then downloaded the read program...
String loc = String(i);
unsigned int j=preferences.getUInt(loc.c_str(),0);
Serial.print(j);
Serial.print(" ");
preferences.end();
void loop() {}
This read back 0,1,2,3,4.... to 365 and then a series of 0's for the rest of the readback for the remaining 635 reads!!!!
I then changed the write to
preferences.putUInt(loc.c_str(),2*i); // double the value in each location
and nothing changed... the new values did not seem to go in . the same answer came back
So, a simple understanding please...
Also there is an EEprom example provided that I cannot get to work, also it says that it is only good for 4.2kB... Why?
ESP32 wroom, Flash Memory preferences.h
tele_player
Re: ESP32 wroom, Flash Memory preferences.h
I suspect you hit a size limit writing to NVS. You should check the return value of each call to putUInt. 4 is good, 0 is error.
Users browsing this forum: ChatGPT-User, Google [Bot], PetalBot, Qwantbot and 4 guests
