With previous versions of the ESP32, there have always been some GPIO pins which may briefly emit a PWM signal at boot or a logic HIGH, causing some undesirable activity in whatever the pins are connected to. There are some guides from people who tested the pins for such behavior such as this one:
https://randomnerdtutorials.com/esp32-p ... nce-gpios/
The problem is that with the different pin amount and layout of the ESP32-S3, these guides are now outdated. Are there any newer references to this somewhere, or do I just need to order a devkit and test it myself? I did not find anything in the datasheet which clearly explains this.
Thanks.
"Safe" GPIO pins for ESP32-S3?
Re: "Safe" GPIO pins for ESP32-S3?
Hello, have you verified those gpios? I do not see default PWM from those pins, the conclusion is so strange. We provide IO state in datasheet for your reference, generally, default value is showed as the table lists.
Users browsing this forum: Bytespider, ChatGPT-User, PerplexityBot and 4 guests
