Camera and I2S audio simultaneously use
takurot
Postby takurot » Wed Aug 10, 2022 2:08 am
I could not find the solution in any where, so please let me ask here.
I use ESP32-WROOVER-DEV board and I want to implement both I2S audio and Camera function. But audio does not play at all when I start esp_camera_fb_get().
I use the library for audio as bellow, and I2S amp MAX98357A is attached to the board.
https://github.com/schreibfaul1/ESP32-a ... e285f16d6f
I confirmed that the single function for camera and audio separately, and they works fine as independent. But not in simultaneously.
I'd like to know that this is even possible.
Code: Untitled.c Select all
#include "esp_camera.h"
#include <HTTPClient.h>
#include <Preferences.h>
#include <WiFi.h>
#include "Audio.h"
#define I2S_DOUT 15
#define I2S_BCLK 12
#define I2S_LRC 33
Serial.setDebugOutput(true);
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
// config.frame_size = FRAMESIZE_UXGA;
config.frame_size = FRAMESIZE_VGA;
config.pixel_format = PIXFORMAT_JPEG; // for streaming
//config.pixel_format = PIXFORMAT_RGB565; // for face detection/recognition
config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
config.fb_location = CAMERA_FB_IN_PSRAM;
config.jpeg_quality = 10;
config.fb_count = 1;
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
sensor_t * s = esp_camera_sensor_get();
// initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1); // flip it back
s->set_brightness(s, 1); // up the brightness just a bit
s->set_saturation(s, -2); // lower the saturation
WiFi.begin(ssid, password);
WiFi.setSleep(false);
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
delay(1500);
audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
audio.setVolume(10);
audio.connecttohost("http://mp3.ffh.de/radioffh/hqlivestream.mp3");
Serial.println("Audio Set");
audio.loop(); //NOT WORKING
// ---- get camera capture
camera_fb_t *fb = NULL;
fb = esp_camera_fb_get(); //Camera can get an image
if (!fb) {
Serial.println("failure: Camera capture");
return;
}else{
Serial.println("Success: Camera capture");
esp_camera_fb_return(fb);
BotondColop
Re: Camera and I2S audio simultaneously use
Postby BotondColop » Wed Aug 10, 2022 7:44 am
Can you share also the defined pin number what are you using to the camera setup?
takurot
Postby takurot » Wed Aug 10, 2022 7:50 am
Thanks for your reply. Camera Pin assigns are as bellow
#define PWDN_GPIO_NUM    -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 21
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 19
#define Y4_GPIO_NUM 18
#define Y3_GPIO_NUM 5
#define Y2_GPIO_NUM 4
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
takurot
Postby takurot » Thu Aug 11, 2022 1:45 am
I did't include the audio definition on the comment above(There is a definition on actual code)
I tried to change the I2C channel, but it did not work either way.
I2S channel 1
Audio audio(false, 3, 1);
I2S channel 0
Audio audio();
BotondColop
Postby BotondColop » Thu Aug 11, 2022 8:08 am
One problem what i think, both of the function use PSRAM
 class AudioBuffer {
// AudioBuffer will be allocated in PSRAM, If PSRAM not available or has not enough space AudioBuffer will be
// allocated in FlashRAM with reduced size
Audio:
you can check this funktion
bool     havePSRAM() { return m_f_psram; };
This can be a problem. Maybe you can test -> AudioBuffer in FlashRAM
Users browsing this forum: ChatGPT-User, Google [Bot], Perplexity-User and 5 guests
