Greetings,
We have seen that there are commands in the ESP AT command set to activate BluFi. We enabled this feature and could see that the ESP32 was advertising the correct service. We were not able to get the Android APP to connect to the module.
Do you have instructions for testing this feature? How do we connect to the ESP32 from the APP? The APP asked for a QR code, but we do not know how to generate this code.
Cheers
Using BluFi
Re: Using BluFi
You can use ESPBLUFI APP to test the BLUFI function of AT, APP download link: https://www.espressif.com/zh-hans/support/download/apps, if you want to use other APP to test this function, you may need your APP adapts it.
Re: Using BluFi
We are seeing an error when we attempt to configure:
We cannot configure a 2.4GHz network with a phone that is connected to a 5GHz network.
Users browsing this forum: No registered users and 63 guests
