RNDIS or NCM with ESP32-S2 (Tinyusb)
kino0924
Postby kino0924 » Mon Aug 22, 2022 9:55 pm
I am trying to implement Ethernet over USB so I can control my board with TCP/IP
I am going to connect from Windows machine so I thought RNDIS or NCM will be suitable.
I followed lots of Tinyusb example as well as ESP-IDF's implementation.
So, I created following code for to create USB Ethernet first but Windows is saying that its "This device cannot start. (Code 10)"
I also did pretty same implementation for ECM, just changing define and configuration_descriptor but no good
I am using VSCode + ESP-IDF v5.0-beta1
Can someone tell me what am I doing wrong?
Thank you.
Code: Untitled.c Select all
#define CFG_TUD_ECM_RNDIS     1
#include <stdlib.h>
#include "esp_log.h"
#include "driver/gpio.h"
#include "freertos/task.h"
#include "tinyusb.h"
#include "sdkconfig.h"
#include "class/net/net_device.h"
static const char *TAG = "example";
#define MAIN_CONFIG_TOTAL_LEN (TUD_CONFIG_DESC_LEN + TUD_RNDIS_DESC_LEN)
#define ALT_CONFIG_TOTAL_LEN (TUD_CONFIG_DESC_LEN + TUD_CDC_ECM_DESC_LEN)
#define NCM_CONFIG_TOTAL_LEN (TUD_CONFIG_DESC_LEN + TUD_CDC_NCM_DESC_LEN)
#define EPNUM_NET_NOTIF 0x81
#define EPNUM_NET_OUT 0x02
#define EPNUM_NET_IN 0x82
// String Descriptor Index
enum
STRID_LANGID = 0,
STRID_MANUFACTURER,
STRID_PRODUCT,
STRID_SERIAL,
STRID_INTERFACE,
STRID_MAC
enum
ITF_NUM_CDC = 0,
ITF_NUM_CDC_DATA,
ITF_NUM_TOTAL
enum
CONFIG_ID_RNDIS = 0,
CONFIG_ID_COUNT
tusb_desc_device_t const desc_device =
.bLength = sizeof(tusb_desc_device_t),
.bDescriptorType = TUSB_DESC_DEVICE,
.bcdUSB = 0x0200,
// Use Interface Association Descriptor (IAD) device class
.bDeviceClass = TUSB_CLASS_MISC,
.bDeviceSubClass = MISC_SUBCLASS_COMMON,
.bDeviceProtocol = MISC_PROTOCOL_IAD,
.bMaxPacketSize0 = CFG_TUD_ENDPOINT0_SIZE,
.idVendor = 0x1234,
.idProduct = 0x5678,
.bcdDevice = 0x0101,
.iManufacturer = STRID_MANUFACTURER,
.iProduct = STRID_PRODUCT,
.iSerialNumber = STRID_SERIAL,
.bNumConfigurations = CONFIG_ID_COUNT // multiple configurations
tusb_desc_strarray_device_t my_string_descriptor = {
[STRID_LANGID] = (const char[]) { 0x09, 0x04 }, // supported language is English (0x0409)
[STRID_MANUFACTURER] = "TinyUSB", // Manufacturer
[STRID_PRODUCT] = "TinyUSB Device", // Product
[STRID_SERIAL] = "123456", // Serial
[STRID_INTERFACE] = "TinyUSB Network Interface" // Interface Description
uint8_t const * tud_rndis_descriptor_device_cb(void)
return (uint8_t const *) &desc_device;
static uint8_t const rndis_configuration[] =
// Config number (index+1), interface count, string index, total length, attribute, power in mA
TUD_CONFIG_DESCRIPTOR(CONFIG_ID_RNDIS+1, ITF_NUM_TOTAL, 0, MAIN_CONFIG_TOTAL_LEN, 0, 100),
// Interface number, string index, EP notification address and size, EP data address (out, in) and size.
TUD_RNDIS_DESCRIPTOR(ITF_NUM_CDC, STRID_INTERFACE, EPNUM_NET_NOTIF, 8, EPNUM_NET_OUT, EPNUM_NET_IN, CFG_TUD_NET_ENDPOINT_SIZE),
void app_main(void)
ESP_LOGI(TAG, "USB initialization");
const tinyusb_config_t tusb_cfg = {
.descriptor = &desc_device,
.string_descriptor = my_string_descriptor,
.external_phy = false,
.configuration_descriptor = rndis_configuration,
ESP_ERROR_CHECK(tinyusb_driver_install(&tusb_cfg));
ESP_LOGI(TAG, "USB initialization DONE");
Code: Untitled.txt Select all
=========================== USB Port13 ===========================
Connection Status : 0x00 (No device is connected)
Port Chain : 2-13
Properties : 0x01
IsUserConnectable : yes
PortIsDebugCapable : no
PortHasMultiCompanions : no
PortConnectorIsTypeC : no
ConnectionIndex : 0x0D (Port 13)
CompanionIndex : 0
CompanionHubSymLnk : USB#ROOT_HUB30#5&178f6c5f&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
CompanionPortNumber : 0x05 (Port 5)
-> CompanionPortChain : 2-5
========================== Summary =========================
Vendor ID : 0x1234 (Micro Science Co., Ltd.)
Product ID : 0x5678
USB Version : 2.0 -> but Device is Full-Speed only
Port maximum Speed : High-Speed (Companion Port 2-5 supports SuperSpeed)
Device maximum Speed : Full-Speed
Device Connection Speed : Full-Speed
Device Manager Problem : 10 (CM_PROB_FAILED_START)
Used Endpoints : 1
======================== USB Device ========================
+++++++++++++++++ Device Information ++++++++++++++++++
Device Description : USB Composite Device
Device ID : USB\VID_1234&PID_5678\123456
Hardware IDs : USB\VID_1234&PID_5678&REV_0101 USB\VID_1234&PID_5678
Driver KeyName : {36fc9e60-c465-11cf-8056-444553540000}\0011 (GUID_DEVCLASS_USB)
Driver : \SystemRoot\System32\drivers\usbccgp.sys (Version: 10.0.22000.1 Date: 2021-06-05)
Driver Inf : C:\WINDOWS\inf\usb.inf
Legacy BusType : PNPBus
Class : USB
Class GUID : {36fc9e60-c465-11cf-8056-444553540000} (GUID_DEVCLASS_USB)
Service : usbccgp
Enumerator : USB
PDO : \Device\USBPDO-3
Location Info : Port_#0013.Hub_#0001
Manufacturer Info : (Standard USB Host Controller)
Capabilities : 0x14 (Removable, UniqueID)
Status : 0x01806400 (DN_HAS_PROBLEM, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code : 10 (CM_PROB_FAILED_START)
Address : 13
HcDisableSelectiveSuspend: 0
EnableSelectiveSuspend : 0
SelectiveSuspendEnabled : 0
EnhancedPowerMgmtEnabled : 0
IdleInWorkingState : 0
WakeFromSleepState : 0
Power State : D3 (supported: D0, D3, wake from D0)
+++++++++++++++++ Registry USB Flags +++++++++++++++++
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags\123456780101
osvc : REG_BINARY 00 00
---------------- Connection Information ---------------
Connection Index : 0x0D (Port 13)
Connection Status : 0x00 (NoDeviceConnected)
Current Config Value : 0x00 (Configuration 0)
Device Address : 0x30 (48)
Is Hub : 0x00 (no)
Device Bus Speed : 0x01 (Full-Speed)
Number Of Open Pipes : 0x00 (0 pipes to data endpoints)
Data (HexDump) : 0D 00 00 00 12 01 00 02 EF 02 01 40 34 12 78 56 ...........@4.xV
01 01 01 02 03 01 00 01 00 30 00 00 00 00 00 00 .........0......
00 00 00 ...
--------------- Connection Information V2 -------------
Connection Index : 0x0D (13)
Length : 0x10 (16 bytes)
SupportedUsbProtocols : 0x03
Usb110 : 1 (yes, port supports USB 1.1)
Usb200 : 1 (yes, port supports USB 2.0)
Usb300 : 0 (no, port not supports USB 3.0) -> but Companion Port 2-5 does
ReservedMBZ : 0x00
Flags : 0x00
DevIsOpAtSsOrHigher : 0 (Device is not operating at SuperSpeed or higher)
DevIsSsCapOrHigher : 0 (Device is not SuperSpeed capable or higher)
DevIsOpAtSsPlusOrHigher : 0 (Device is not operating at SuperSpeedPlus or higher)
DevIsSsPlusCapOrHigher : 0 (Device is not SuperSpeedPlus capable or higher)
ReservedMBZ : 0x00
Data (HexDump) : 0D 00 00 00 10 00 00 00 03 00 00 00 00 00 00 00 ................
---------------------- Device Descriptor ----------------------
bLength : 0x12 (18 bytes)
bDescriptorType : 0x01 (Device Descriptor)
bcdUSB : 0x200 (USB Version 2.0) -> but device is Full-Speed only
bDeviceClass : 0xEF (Miscellaneous)
bDeviceSubClass : 0x02
bDeviceProtocol : 0x01 (IAD - Interface Association Descriptor)
bMaxPacketSize0 : 0x40 (64 bytes)
idVendor : 0x1234 (Micro Science Co., Ltd.)
idProduct : 0x5678
bcdDevice : 0x0101
iManufacturer : 0x01 (String Descriptor 1)
iProduct : 0x02 (String Descriptor 2)
iSerialNumber : 0x03 (String Descriptor 3)
bNumConfigurations : 0x01 (1 Configuration)
Data (HexDump) : 12 01 00 02 EF 02 01 40 34 12 78 56 01 01 01 02 .......@4.xV....
03 01 ..
----------------- Device Qualifier Descriptor -----------------
Error : ERROR_GEN_FAILURE (because the device has problem code CM_PROB_FAILED_START)
-------------------- String Descriptors -------------------
String descriptors are not available (because the device has problem code CM_PROB_FAILED_START)
Users browsing this forum: Barkrowler, ChatGPT-User, meta-externalagent, Semrush [Bot] and 5 guests
