SPI2 mode octal not work
Posted: Mon Aug 29, 2022 4:22 am
by daonguyen_iot47
When configuring spi in octal mode. Error message not all required capabilities satisfied and esp32 is reset continuously.
I went into the library and removed the line that checks for SPI_CHECK(missing_flag == 0, "not all required capabilities satisfied.", ESP_ERR_INVALID_ARG);
The esp32 chip is no longer reset, but no data is sent on the 8 data pins even though there is still a clock signal.
Quad mode works fine
Re: SPI2 mode octal not work
Posted: Mon Aug 29, 2022 5:40 am
by Sprite
ESP32 does not support octal mode. The ESP32S2 and S3 do. Removing the check to see if it's supported, unsurprisingly, does not magically give the ESP32 hardware these capabilities.
