I would like to know if it was possible somehow to keep connected the micro usb of the esp32-cam-mb to load the module and in the meantime check the consumption(Ampere) from a multimeter.
i tried to connect the multimeter in any way but failed
connecting esp32 cam to a multimeter
Re: connecting esp32 cam to a multimeter
Sure. Take an USB lead, cut off the outer isolation, find the red wire, cut it in two, connect multimeter in between. Make sure the internal resistance / burden voltage of your multimeter is not too high: if the voltage drop of the multimeter is too high, your ESP32 may brown out. (You can try switching to the 10A range when you think that happens.)
