assertion "s_list_lock" failed: error while initialisng WiFi
Posted: Fri Sep 02, 2022 5:22 am
i am trying to initialize wifi in my project, i had done this earlier i had written small piece of code earlier that was working fine, but i have tried copying same code in new project and it doesnt work, the snippet of code is as below,
error log generated is as below
any help wrt above issue would be much appreciated ? let me know if you need any more information
app_main(){
//Initialize NVS
esp_err_t ret = nvs_flash_init();
if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND) {
ESP_ERROR_CHECK(nvs_flash_erase());
ESP_ERROR_CHECK(ret);
/** init GPIO first for default pin */
init_gpio();
#if 1
// Initialize TCP/IP network interface (should be called only once in application)
ESP_ERROR_CHECK(esp_netif_init());
#endif
// Create default event loop that running in background
ESP_ERROR_CHECK(esp_event_loop_create_default());
#if 0
tcpip_adapter_init();
#endif
/*V42 onboard esp netif uses instead of tcpip_adapter*/
esp_netif_t *local_sta_netif = esp_netif_create_default_wifi_sta();
#if __WIFI_MANAGER_LVL0__
ESP_LOGI(TAG, "NETIF from sta = 0x%X", (uint32_t) local_sta_netif );
#endif
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&cfg));
/*loop forever to detect error*/
for(;;)
}ESP IDF related informationD (1586) esp_netif_lwip: LwIP stack has been initialized
D (1596) esp_netif_lwip: esp-netif has been successfully initialized
D (1606) event: running task for loop 0x3ffbdbc4
D (1606) event: created task for loop 0x3ffbdbc4
D (1606) event: created event loop 0x3ffbdbc4
V (1616) esp_netif_objects: esp_netif_next_unsafe 0x0
V (1626) esp_netif_objects: esp_netif_next_unsafe 0x0
D (1626) esp_netif_objects: esp_netif_add_to_list 0x3ffb8748
V (1636) esp_netif_objects: esp_netif_next_unsafe 0x0
D (1646) esp_netif_objects: esp_netif_add_to_list netif added successfully (total netifs: 1)
assertion "s_list_lock" failed: file "D:/esp_tool/v42/esp-idf/components/esp_netif/esp_netif_objects.c", line 57, function: esp_I (1656) WIFI_API: NETIF from sta = 0x3FFB8748
netif_list_unlock
abort() was called at PC 0x400d3937 on core 0
0x400d3937: __assert_func at /builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/stdlib/assert.c:62 (discriminator 8)
Backtrace:0x4008741b:0x3ffc0980 0x40087ac5:0x3ffc09a0 0x4008e7c2:0x3ffc09c0 0x400d3937:0x3ffc0a30 0x400effbd:0x3ffc0a60 0x400f01f7:0x3ffc0a80 0x400f0c39:0x3ffc0aa0 0x400f197a:0x3ff
c0ad0 0x400d356a:0x3ffc0b00 0x400898d1:0x3ffc0be0
0x4008741b: panic_abort at D:/esp_tool/v42/esp-idf/components/esp_system/panic.c:330
0x40087ac5: esp_system_abort at D:/esp_tool/v42/esp-idf/components/esp_system/system_api.c:106
0x4008e7c2: abort at D:/esp_tool/v42/esp-idf/components/newlib/abort.c:46
0x400effbd: esp_netif_list_unlock at D:/esp_tool/v42/esp-idf/components/esp_netif/esp_netif_objects.c:57 (discriminator 1)
0x400f01f7: esp_netif_get_handle_from_ifkey at D:/esp_tool/v42/esp-idf/components/esp_netif/esp_netif_objects.c:187
0x400f0c39: esp_netif_new at D:/esp_tool/v42/esp-idf/components/esp_netif/lwip/esp_netif_lwip.c:402
0x400f197a: esp_netif_create_default_wifi_sta at D:/esp_tool/v42/esp-idf/components/esp_wifi/src/wifi_default.c:322
0x400d356a: wifi_manager at D:/projects/esp32/v42/eport/v300/main/wifi_api.c:896
0x400898d1: vPortTaskWrapper at D:/esp_tool/v42/esp-idf/components/freertos/xtensa/port.c:143
i have attached SDKconfig file415) cpu_start: Project name: blink
I (420) cpu_start: App version: 1
I (424) cpu_start: Compile time: Sep 2 2022 10:31:36
I (430) cpu_start: ELF file SHA256: a5000b365733cf89...
I (436) cpu_start: ESP-IDF: v4.2.2
I (441) cpu_start: Starting app cpu, entry point is 0x400812ac
