ESP32 - telegram disable/enable notifications
levinlinux
Postby levinlinux » Sun Sep 04, 2022 9:33 pm
Guys, I've already managed to make the telegram bot receive messages from the X condition state as I put it in the code, but in this condition it keeps sending a message all the time, could someone help me how do I disable notifications and enable when, like this does not pollute the chat.
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
#include <ArduinoJson.h>
// Replace with your network credentials
const char* ssid = "ssid";
const char* password = "password";
#define BOTtoken "xxxx:xxxxxx"
#define CHAT_ID "xxxxxx"
WiFiClientSecure client;
UniversalTelegramBot bot(BOTtoken, client);
const int trigPin = 5;
const int echoPin = 18;
//Telegram
//define sound speed in cm/uS
#define SOUND_SPEED 0.034
//#define CM_TO_INCH 0.393701
long duration;
float distanceCm;
float distanceInch;
   pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
  pinMode(echoPin, INPUT); // Sets the echoPin as an Input
  // Attempt to connect to Wifi network:
  Serial.print("Connecting Wifi: ");
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  client.setCACert(TELEGRAM_CERTIFICATE_ROOT); // Add root certificate for api.telegram.org
    Serial.print(".");
    delay(500);
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("IP address: ");
 bot.sendMessage(CHAT_ID, "Bot caixa de agua!", "");
void loop() {  // Clears the trigPin
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  // Sets the trigPin on HIGH state for 10 micro seconds
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Reads the echoPin, returns the sound wave travel time in microseconds
  duration = pulseIn(echoPin, HIGH);
  delay (2000);
  // Calculate the distance
  distanceCm = duration * SOUND_SPEED/2;
  // Convert to inches
//  distanceInch = distanceCm * CM_TO_INCH;
if(  (distanceCm > 0) && (distanceCm <= 40)   )
  Serial.println("Caixa 100% cheia!");
 // bot.sendMessage(CHAT_ID, "Caixa 100% cheia!", "");
} else
if(  (distanceCm > 40) && (distanceCm <= 50)  )
  Serial.println("Caixa 70% cheia!");
//  bot.sendMessage(CHAT_ID, "Caixa 70% cheia!", "");
}else
if(  (distanceCm > 50) && (distanceCm <= 70)  )
  Serial.println("Caixa 50% cheia!");
}else
if(  (distanceCm > 70) && (distanceCm <= 90)  )
  Serial.println("Caixa quase vazia!");
}else
if(  (distanceCm > 90) && (distanceCm <= 150)  )
  Serial.println("Caixa vazia!");
  bot.sendMessage(CHAT_ID, "Caixa vazia!", "");
  // Prints the distance in the Serial Monitor
  Serial.print("Distance (cm): ");
  Serial.println(distanceCm);
//  Serial.print("Distance (inch): ");
//  Serial.println(distanceInch);
  delay(1000);
cloudmiracle
Re: ESP32 - telegram disable/enable notifications
Postby cloudmiracle » Thu Aug 31, 2023 7:28 pm
In order to set your code to send Telegram notification only once when the event occurs and not continuously, add the following code to the sketch so that the event occurs ----sends notification-----resets event.
bool current_state1 = LOW;
bool previous_state1 = LOW;
void loop();
current_state1 = digitalRead(input1);
if (current_state1 != previous_state1) {
if (current_state1 == HIGH) {
delay (100);
bot.sendMessage(CHAT_ID, "Unit1 is OFF", "");}
if (current_state1 == LOW){
delay (100);
bot.sendMessage(CHAT_ID, "Unit1 is ON", "");}
previous_state1 = current_state1;
In this manner the sketch will send notification only once when input1 becomes HIGH. It will only send notification next time when the input1 goes LOW and then HIGH again.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 2 guests
