Static noise from powersupply on TTGO web audio player
larsdp
Postby larsdp » Mon Sep 05, 2022 8:07 am
I’m a newbie :P I have a ttgo board with a webradio script installed. Everything works nicely when the usb-c power is coming from my imac, but when i switch over to a 220v power supply to usb-c to power the ttgo the speaker playing music is filled with low static noise.
Why is there a difference from the USB-C on my iMac to the power supply and what can I do to make the noise go away since its almost killing the audio.
Thanks in advance.
LJH
Re: Static noise from powersupply on TTGO web audio player
Postby LJH » Wed Sep 07, 2022 3:23 am
Could you show us more details about this 220V to typec adaptor?
Postby Sprite » Thu Sep 08, 2022 2:25 am
Make sure to use a brand-name high-quality non-fake power supply. Especially cheap and fake USB power supplies have horrible noise suppression.
larsdp
Postby larsdp » Fri Sep 09, 2022 7:17 am
I'm using an 220v to usb power Apple adaptor and also tested a Samsung with the same result. What would you remcommend buying? Or would it be better to use the dedicated 5v input on the board with a classic power supply?
Thanks!
https://www.teknikdele.dk/upload/zoom/a ... ter-ny.jpg
larsdp
Postby larsdp » Fri Sep 09, 2022 7:30 am
Not sure if my reply got send. I'm using an Apple 220v to usb and then a usb cable to usb-c aprox 10 cm long.
Also tried with a Samsung phone adaptor.
Users browsing this forum: Amazon [Bot], Semrush [Bot] and 3 guests
