Bluetooth SPP in VFS mode and select()
Air_Hamster
Postby Air_Hamster » Fri Sep 09, 2022 6:12 am
Hi!
Is it possible to use Bluetooth SPP in VFS mode with select()?
I'm trying to implement non-blocking reading, but my application crashes at select() operation.
write() and read() to the SPP file descriptor works fine.
Code example:
Code: Untitled.cpp Select all
static void spp_read_handle(void *param)
int size = 0;
int read_bytes;
int spp_fd = (int)param;
uint8_t *spp_data = (uint8_t *)malloc(SPP_DATA_LEN);
if (!spp_data) {
ESP_LOGE(TAG, "malloc spp_data failed, fd:%d", spp_fd);
while (true) {
int s = 0;
fd_set rfds;
struct timeval tv = {
.tv_sec = 5,
.tv_usec = 0,
FD_ZERO(&rfds);
FD_SET(spp_fd, &rfds);
s = select(spp_fd + 1, &rfds, NULL, NULL, &tv); // crashed here
if (s < 0) {
ESP_LOGE(TAG, "Select failed: errno %d", errno);
} else if (s == 0) {
ESP_LOGI(TAG, "Timeout has been reached and nothing has been received");
ESP_LOGE(TAG, "Select: data is ready for reading");
Panic back trace, but it's not so usefull:
Guru Meditation Error: Core  0 panic'ed (Instr
FetchProhibited). Exception was unhandled.
Core  0 register dump:
PC      : 0x00000000  PS      : 0x00060230  A0      : 0x800f38a6  A1      : 0x3fffa540
A2      : 0x3ffef6f0  A3      : 0x00000005  A4      : 0x00000001  A5      : 0x00000000
A6      : 0x00000005  A7      : 0x3ffc311c  A8      : 0x800d3d60  A9      : 0x3fffa520
A10     : 0x00000000  A11     : 0x0000001c  A12     : 0x80095cf5  A13     : 0x3ffdb7d0
A14     : 0x00000003  A15     : 0x00060323  SAR     : 0x0000001b  EXCCAUSE: 0x00000014
EXCVADDR: 0x00000000  LBEG    : 0x00000000  LEND    : 0x00000000  LCOUNT  : 0x00000000
Backtrace:0xfffffffd:0x3fffa5400x400f38a3:0x3fffa5b0 0x40095b9d:0x3fffa5e0
0x400f38a3: spp_read_handle(void*) at /home/ilia.lutchenko/workspace/project/build/../firmware/bluetooth/bt_classic.cpp:115
0x40095b9d: vPortTaskWrapper at /home/ilia.lutchenko/workspace/project/build/../esp-idf/components/freertos/port/xtensa/port.c:131
Ilia Lutchenko
Embedded Engineer
lin_yi
Re: Bluetooth SPP in VFS mode and select()
Postby lin_yi » Thu Jul 27, 2023 12:50 am
Hello, did you solve the problem? I've met it now. Thank you.
Users browsing this forum: Amazon [Bot], Baidu [Spider], Bytespider, ChatGPT-User, Google [Bot], PetalBot, Qwantbot and 0 guests
