conflict between the inputs
ayman.dab
Postby ayman.dab » Thu Sep 15, 2022 5:06 am
Hello, I have my own system and when I need to change one input the other one change but the desired doesn't, any advice ?
When I change the Current level from application, Full level changes and the current remains the same and vice versa
write call back function code:
void write_callback(Device *device, Param *param, const param_val_t vall, void *priv_data, write_ctx_t *ctx)
  const char *device_name = device->getDeviceName();
  const char *param_name = param->getParamName();
  if (strcmp(param_name,"Current level (cm)") == 0) {
    Serial.printf("Received value = %2.2f for %s - %s\n", vall.val.f, device_name, param_name);
    curlevel = vall.val.f;
    val =curlevel ;
    param->updateAndReport(vall);
    set_value();
  else if (strcmp(param_name, "Full volume(L)") == 0) {
    full_volume = vall.val.f;
    preferences.putInt("full_volume",full_volume);
   else if (strcmp(param_name, "Full level(cm)") == 0) {
    fullevel = vall.val.f;
    val = fullevel ;
    full_value();
create the parameters for device code:
  Param currentlevel("Current level (cm)", "custom.param.clevel", value((float)DEFAULT_current_level), PROP_FLAG_WRITE );
  calibration.addParam(currentlevel);
  Param fulllevel("Full level(cm)", "custom.param.flevel", value((float)DEFAULT_full_level), PROP_FLAG_WRITE );
  calibration.addParam(fulllevel);
  Param fullvolume("Full volume(L)", "custom.param.fvolume", value((float)DEFAULT_full_volume), PROP_FLAG_WRITE );
  calibration.addParam(fullvolume);
