Issue when trying to import existing projects into IDF
c4corvettelover
Postby c4corvettelover » Tue Sep 20, 2022 4:44 pm
I am having an issue when importing an existing ESP32 project into the ESP-IDF with Eclipse CDT 09-2022 Version.
When trying to build any project I get the following error in console "No Toolchain found for Target Local".
I also am not able to change the launch target to "ESP" as I can with example projects.
I just reinstalled IDF 4.42 and CDT V0922 along with Java SE.
Any help would be greatly appreciated!
Thanks,
Steve
Error Message
Eclipse Error No Toolchain.PNG (134.27 KiB) Viewed 3719 times
kondalkolipaka
Re: Issue when trying to import existing projects into IDF
Postby kondalkolipaka » Wed Sep 21, 2022 3:57 pm
How did you import the project? if you've imported using this approach, the launch configuration for the project is created automatically and you will see default launch targets.
