Using MQTT with sim7600 cell modem
Posted: Fri Oct 14, 2022 12:11 am
This is a cell modem only configuration, no wifi. I am using HiveMQ as the broker. If I use a wifi connection (temporaily) all works correctly. If I take out the wifi, then there is an error on the esp_mqtt_client_init. The broker host name is a long unique name like
I know the cell modem makes a connection a network as I can get an ip address from the broker host name. If I pass the long broker name to the init via cfg.host, I get the error
To compound the problem, I have to include
or else I get nasty errors. I am using TinyGSM to manage the cell modem.
Any suggestions what to do?
84053a451db5xxxxxxbaa.s1.eu.hivemq.cloudCode: Select all
17:06:48.469 -> E (44201) esp-tls: couldn't get hostname for :84053451db56xxxxxebaa.s1.eu.hivemq.cloud: getaddrinfo() returns 202, addrinfo=0x0Code: Select all
WiFi.mode (WIFI_MODE_STA);or else I get nasty errors. I am using TinyGSM to manage the cell modem.
