Web Page Request Not Working Correctly
MrGadget
Postby MrGadget » Wed Oct 19, 2022 11:47 pm
I have an EmonCMS running on my Raspberry Pi on my local network which collects data from various sensors based on the ESP processors. The EmonCMS allows me to store and display the data in many ways.
I can retrieve data for id=1 using a web browser:
Code: Untitled.c Select all
http://192.168.11.235/feed/value.json?id=1
And I get the results for id 1.
Or, I can retrieve data for id=2 using a web browser:
http://192.168.11.235/feed/value.json?id=2
And I get the results for id 2.
However using the ESP32 only when id=1 does it give me correct data (when I un-comment line 4 below)
But, if I un-comment line 5 (line 4 is commented out) then I get a 406 error:
{"success":false,"message":"406 Not Acceptable. Route not found"}
Now this is just my example, I have id's that go up to 46 and they all work in a web browser but only id=1 works with the code below running on my ESP.
Does anyone know what my problem might be?
Code: Untitled.cpp Select all
if ((WiFi.status() == WL_CONNECTED)) { //Check the current connection status
HTTPClient http;
//http.begin("http://192.168.11.235/feed/value.json?id=1"); // THIS ONE WORKS
//http.begin("http://192.168.11.235/feed/value.json?id=2"); // THIS ONE FAILS
int httpCode = http.GET(); // get 406 Not Acceptable. Route not found"
if (httpCode > 0) { //Check for the returning code
String payload = http.getString();
Serial.println(httpCode); // 200 which is for OK response
Serial.println(payload); // data
else {
Serial.println("Error on HTTP request");
http.end(); //Free the resources
delay(10000);
