Help with the example of Esp32 examples\storage\sd_card\sdspi\main
Cardan783
Postby Cardan783 » Fri Oct 21, 2022 2:42 am
First of all, a cordial greeting to all wishing that you are all well, good to the point.
I have made the example of Esp32 to use a microSD card as a data storage medium, the idea is that of a datalogger. The example works perfectly fine, a file called hello.txt is created and then renamed to foo.txt.
Now in my project I get the date using the rtc of the same Esp32 and in an array type variable I format the date only with the current day and month. Now that char that we will call date (char date []="20 OCTOBER") only, for example; I want to use that char as a name for a new bone data file that the next day if, for example, the first file is called OCTOBER 20 and when the date changes to OCTOBER 21, a new file with that name is created. My goal is to be able to have the data separated into different files for each day.
Now I'm going to leave you the esp32 example code and I'm going to show you what I've tried.
I hope and you can understand me and even more you can help me. Thank you very much to all.
/* SD card and FAT filesystem example.
// This example uses SPI peripheral to communicate with SD card.
#include <string.h>
#include <sys/unistd.h>
#include <sys/stat.h>
#include "esp_vfs_fat.h"
#include "sdmmc_cmd.h"
static const char *TAG = "example";
#define MOUNT_POINT "/sdcard"
// Pin mapping
#if CONFIG_IDF_TARGET_ESP32
#define PIN_NUM_MISO 2
#define PIN_NUM_MOSI 15
#define PIN_NUM_CLK  14
#define PIN_NUM_CS   13
#elif CONFIG_IDF_TARGET_ESP32S2
// adapted for internal test board ESP-32-S3-USB-OTG-Ev-BOARD_V1.0 (with ESP32-S2-MINI-1 module)
#define PIN_NUM_MISO 37
#define PIN_NUM_MOSI 35
#define PIN_NUM_CLK  36
#define PIN_NUM_CS   34
#elif CONFIG_IDF_TARGET_ESP32C3
#define PIN_NUM_MISO 6
#define PIN_NUM_MOSI 4
#define PIN_NUM_CLK  5
#endif //CONFIG_IDF_TARGET_ESP32 || CONFIG_IDF_TARGET_ESP32S2
#if CONFIG_IDF_TARGET_ESP32S2
#define SPI_DMA_CHAN    host.slot
#define SPI_DMA_CHAN    SPI_DMA_CH_AUTO
#else
#define SPI_DMA_CHAN    1
#endif
void app_main(void)
    esp_err_t ret;
    // Options for mounting the filesystem.
    // If format_if_mount_failed is set to true, SD card will be partitioned and
    // formatted in case when mounting fails.
    esp_vfs_fat_sdmmc_mount_config_t mount_config = {
#ifdef CONFIG_EXAMPLE_FORMAT_IF_MOUNT_FAILED
        .format_if_mount_failed = true,
#else
        .format_if_mount_failed = false,
#endif // EXAMPLE_FORMAT_IF_MOUNT_FAILED
        .max_files = 5,
        .allocation_unit_size = 16 * 1024
    sdmmc_card_t *card;
    const char mount_point[] = MOUNT_POINT;
    ESP_LOGI(TAG, "Initializing SD card");
    // Use settings defined above to initialize SD card and mount FAT filesystem.
    // Note: esp_vfs_fat_sdmmc/sdspi_mount is all-in-one convenience functions.
    // Please check its source code and implement error recovery when developing
    // production applications.
    ESP_LOGI(TAG, "Using SPI peripheral");
    sdmmc_host_t host = SDSPI_HOST_DEFAULT();
    spi_bus_config_t bus_cfg = {
        .mosi_io_num = PIN_NUM_MOSI,
        .miso_io_num = PIN_NUM_MISO,
        .sclk_io_num = PIN_NUM_CLK,
        .quadwp_io_num = -1,
        .quadhd_io_num = -1,
        .max_transfer_sz = 4000,
    ret = spi_bus_initialize(host.slot, &bus_cfg, SPI_DMA_CHAN);
    if (ret != ESP_OK) {
        ESP_LOGE(TAG, "Failed to initialize bus.");
        return;
    // This initializes the slot without card detect (CD) and write protect (WP) signals.
    // Modify slot_config.gpio_cd and slot_config.gpio_wp if your board has these signals.
    sdspi_device_config_t slot_config = SDSPI_DEVICE_CONFIG_DEFAULT();
    slot_config.gpio_cs = PIN_NUM_CS;
    slot_config.host_id = host.slot;
    ESP_LOGI(TAG, "Mounting filesystem");
    ret = esp_vfs_fat_sdspi_mount(mount_point, &host, &slot_config, &mount_config, &card);
        if (ret == ESP_FAIL) {
            ESP_LOGE(TAG, "Failed to mount filesystem. "
                     "If you want the card to be formatted, set the EXAMPLE_FORMAT_IF_MOUNT_FAILED menuconfig option.");
            ESP_LOGE(TAG, "Failed to initialize the card (%s). "
                     "Make sure SD card lines have pull-up resistors in place.", esp_err_to_name(ret));
        return;
    ESP_LOGI(TAG, "Filesystem mounted");
    // Card has been initialized, print its properties
    sdmmc_card_print_info(stdout, card);
    // Use POSIX and C standard library functions to work with files.
    // First create a file.
    const char *file_hello = MOUNT_POINT"/hello.txt";
    ESP_LOGI(TAG, "Opening file %s", file_hello);
    FILE *f = fopen(file_hello, "w");
    if (f == NULL) {
        ESP_LOGE(TAG, "Failed to open file for writing");
        return;
    fprintf(f, "Hello %s!\n", card->cid.name);
    fclose(f);
    ESP_LOGI(TAG, "File written");
    char new_nom[]"nueva_fecha.txt";//for example here I would have the data of the new date this is only the last thing I try
    const char *file_foo =  MOUNT_POINT"/foo.txt";  //and I want to place it here changing foo.txt for new_nom
            /*Example*/
    const char *file_foo =  MOUNT_POINT new_nom;
    // Check if destination file exists before renaming
    struct stat st;
    if (stat(file_foo, &st) == 0) {
        // Delete it if it exists
        unlink(file_foo);
    // Rename original file
    ESP_LOGI(TAG, "Renaming file %s to %s", file_hello, file_foo);
    if (rename(file_hello, file_foo) != 0) {
        ESP_LOGE(TAG, "Rename failed");
        return;
    // Open renamed file for reading
    ESP_LOGI(TAG, "Reading file %s", file_foo);
    f = fopen(file_foo, "r");
    if (f == NULL) {
        ESP_LOGE(TAG, "Failed to open file for reading");
        return;
    // Read a line from file
    char line[64];
    fgets(line, sizeof(line), f);
    fclose(f);
    // Strip newline
    char *pos = strchr(line, '\n');
    if (pos) {
        *pos = '\0';
    ESP_LOGI(TAG, "Read from file: '%s'", line);
    // All done, unmount partition and disable SPI peripheral
    esp_vfs_fat_sdcard_unmount(mount_point, card);
    ESP_LOGI(TAG, "Card unmounted");
    //deinitialize the bus after all devices are removed
    spi_bus_free(host.slot);
jgustavoam
Contact:
Re: Help with the example of Esp32 examples\storage\sd_card\sdspi\main
Postby jgustavoam » Mon Jun 05, 2023 3:16 am
Hi Cardan,
I think this example can be useful:
https://randomnerdtutorials.com/esp32-c ... timestamp/
Retired IBM Brasil
