Flashing over JTAG: OpenOcd Target not halted!
nils11
Postby nils11 » Fri Oct 21, 2022 1:43 pm
Hi there,
I’ve got a problem flashing via JTAG.
Problem description:
After a specific firmware is flashed (and working) the next attempt to flash the same or any other firmware over JTAG fails. If I try to flash the same Firmware over UART there is no problem. Also clearing the Flash over UART, and then flashing the Firmware over JTAG works.
I’ve noticed that when the OpenOcd log shows:
** Programming Started **
Info : [esp32.cpu0] Debug controller was reset.
Info : [esp32.cpu0] Core was reset.
Here at this point the ESP32 restarts and starts executing Code. I can confirm this by the UART output of the running code.
After some time the Log continues
Error: Target not halted
Error: failed erasing sectors 16 to 301
embedded:startup.tcl:1184: Error: ** Programming Failed **
Yeah, the same as i already noticed -> ESP32 (Target) is not halted
The problem seems to be nearly the same as mentioned in:
https://github.com/espressif/openocd-esp32/issues/223
But I'm already using the newest OpenOcd version: v0.11.0-esp32-20220706 (2022-07-06-15:48)
The firmware doesn't use any of the JTAG or bootstrap GPIO pins. Flashing over JTAG worked for a long time, until adding some code to ping a server. I've encountered this problem once before (here it was mDns) and as a workaround commented code I don't need at the moment until i ran again in this error. It feels like a certain "amount" of code is triggering this error. Very strange.
System properties
Windows 10 64-bit;
VSCode+ PlatformIO -> Espressif 32 Platform (5.2.0)
Which is based on: IDF framework 4.4.2
OpenOcd v0.11.0-esp32-20220706 (2022-07-06-15:48)
Hardware
ESP-WROVER-KIT V4.1
(also tried a custom PCB including ESP32-WROOM-32E with Segger as JTAG tool)
OpenOcd log
Here is the full OpenOcd log including the command to start flashing:
openocd -d2 -f board/esp32-wrover-kit-3.3v.cfg -c "adapter speed 20000"
-c "program_esp {{C:\...\projectname\.pio\build\esp-wrover-kit\firmware.bin}} 0x10000 verify"
-c "program_esp {{C:\...\projectname\.pio\build\esp-wrover-kit\bootloader.bin}} 0x1000 verify"
-c "program_esp {{C:\...\projectname\.pio\build\esp-wrover-kit\partitions.bin}} 0x8000 verify"
-c "reset run; shutdown"
Open On-Chip Debugger  v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
adapter speed: 20000 kHz
Warn : Interface already configured, ignoring
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : starting gdb server for esp32.cpu0 on 3333
Info : [esp32.cpu0] requesting target halt and executing a soft reset
Info : [esp32.cpu0] Target halted, PC=0x4019D09E, debug_reason=00000000
Info : Set GDB target to 'esp32.cpu0'
Info : [esp32.cpu1] Target halted, PC=0x4019D09E, debug_reason=00000000
Info : [esp32.cpu0] Target halted, PC=0x500000CF, debug_reason=00000000
Info : [esp32.cpu1] requesting target halt and executing a soft reset
Info : [esp32.cpu0] Target halted, PC=0x40000400, debug_reason=00000000
Info : [esp32.cpu1] Debug controller was reset.
Info : [esp32.cpu1] Core was reset.
Info : [esp32.cpu1] Target halted, PC=0x40000400, debug_reason=00000000
Info : [esp32.cpu0] Target halted, PC=0x40092612, debug_reason=00000001
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 168 KB
Info : Flash mapping 1: 0x40020 -> 0x400d0020, 832 KB
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Auto-detected flash bank 'esp32.cpu1.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu1.flash' size 4096 KB
Error: timed out while waiting for target halted
Error: xtensa_wait_algorithm: not halted 0, pc 0x4019d09e, ps 0x60820
Error: Failed to wait algorithm (-302)!
Error: Algorithm run failed (-302)!
in procedure 'program_esp'
in procedure 'program_error' called at file "C:/Users/username/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp_common.cfg", line 171
at file "embedded:startup.tcl", line 1184
Long version (-d3) is attached
OpenOcdLogD3.txt
Long version (-d3)
(175.84 KiB) Downloaded 26143 times
Thanks!
Any help is appreciated
topphisitian
Re: Flashing over JTAG: OpenOcd Target not halted!
Postby topphisitian » Mon May 15, 2023 9:22 am
Have anyone found a solution.
packn365
Postby packn365 » Fri Jul 14, 2023 3:44 pm
Can you try to full flash erase? So run the command below.
esptool.py --port=[Your COM port] --chip esp32 erase_flash
I've got the same issue.
It works again magically after I erased the flash.
It's still working even though I re-write the image which had this JTAG problem.
I don't know why but worth to try I think.
qubdtq
Postby qubdtq » Sat Dec 09, 2023 6:53 am
I'm seeing similar -- for me it seems to be triggered when the written flash size exceeds some unknown amount... [edit: nope, but see here for further experiments]
My procedure is either to switch to a smaller project and do a non-debug upload, or erase flash as suggested by the previous poster. Then I can go back to the "large" project and do a debug upload and it works, but only one time. Then the board is "broken" for debugging until I repeat the procedure.
Very annoying. Fingers crossed that this can be figured out at some point.
My post at PIO: https://community.platformio.org/t/inte ... lems/37168
paco1979
Postby paco1979 » Wed Jan 24, 2024 8:26 pm
Hey guys, I have noticed that is related to CPU (ESP32­WROOM­32UE) loading, if I have some task printing fast (in my project I have several classes doing heavy I2c and SPI stuff) then it fails the flash over JTAG. I made sure to not use any of the strapping GPIO (expect the ones connected to JTAG) and no change. I have to put it on boot mode then it works. But it is very annoying.
Now if I flash and older version where say I do not have these crazy prints, then it goes back to normal.
Im trying to understand why openOCD cant stop the CPU if is running fast.
