ESP32-C3 putting device into download boot
Cyclocyclone
Postby Cyclocyclone » Wed Oct 26, 2022 9:20 pm
So I am designing a dev board based on ESP32-C3 (ESP32-C3FN4) and I am not sure if I am correct with connections for download boot.
Is it enough to put tactile switched on GPIO2 and GPIO8 towards VCC and pull-down on GPIO9.
Also should I include connector in case the device needs to be flashed?
aid219
Re: ESP32-C3 putting device into download boot
Postby aid219 » Fri Oct 28, 2022 11:15 am
U need to start your esp32 with Low level on Boot pin for begin bootloader.In normal mode u can hold HIGH level on this pin by pullup him with 10k, for example. Usually u can use 2 buttons for switching mode, 1 - for connect boot pin to GND, 2 - for pull RST(EN) pin to GND - for restarting esp32(u need to pullup it too).Also u can use special schemes which will do it automatically
Cyclocyclone
Postby Cyclocyclone » Mon Nov 14, 2022 9:16 pm
Thanks, can you please provide me with special schematics for auto boot?
Also would you put programming header in case bootloader fails?
