ESP32 + JSN-SR04T wont read more than 40cm
JacoFourie
Postby JacoFourie » Thu Nov 10, 2022 9:25 pm
Hi all. If I use the JSN-SR04T sensor on the ESP32 it will read fine between 20 - 40 cm.
It will not read more than 40 CM yet the same code on an Arduino Uno will read up to 4 meters.
Why is that?
#define ECHOPIN 17
#define TRIGPIN 16
  pinMode(ECHOPIN,INPUT_PULLUP);
  pinMode(TRIGPIN, OUTPUT);
  digitalWrite(ECHOPIN, HIGH);
  digitalWrite(TRIGPIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGPIN, HIGH);
  delayMicroseconds(15);
  int distance = pulseIn(ECHOPIN, HIGH, 26000);
  distance=distance/58;
  Serial.print(distance);
  Serial.println("   cm");
  delay(1000);
if I use a 5v 3 amp power supply the distance will jump around from 40 - 200 cm.
JacoFourie
Re: ESP32 + JSN-SR04T wont read more than 40cm
Postby JacoFourie » Fri Nov 18, 2022 6:35 pm
Anybody ?????
