ESP32-S3FH4R2 footprint (PCB land pattern)
Sansveni
Postby Sansveni » Tue Nov 22, 2022 3:23 pm
I need help with a recommended footprint for the QFNWB (7x7 mm) package used in the ESP32-S3FH4R2, per esp32-s3_datasheet_en.pdf v1.4. I was previously using the ESP32-S3-WROOM-1_V1.3_Reference_Design Gerbers as a reference, however the ESP32-S3FH4R2 has a different package with a much bigger ground pad. This is concerning because this probably means I can't route vias/traces underneath the chip.
I can't find a reference design that has the ESP32-S3FH4R2, has one been released yet? If not, when is that expected to be available? Thanks.
MurphyMo
Re: ESP32-S3FH4R2 footprint (PCB land pattern)
Postby MurphyMo » Mon Nov 28, 2022 6:41 am
Hi Sansveni,
I am sorry that currently, we have no reference design for ESP32-S3FH4R2, and there is no scheduled release plan either in the near future. You may just refer to the existing reference design documents for other ESP32-S3 series chips, like what you are already doing.
If you meet with any technical problem, please leave reply and we will follow up on the issue!
Users browsing this forum: Google [Bot], Perplexity-User and 5 guests
