bq24735 I2C communication
fordmiki
Postby fordmiki » Fri Dec 02, 2022 4:51 pm
Dear all,
I am trying to setup the bq24735 power management unit with ESP32-WROOM-32.
I have a problem with writing information to the BQ_CHARGE_OPTION_REG. Here is a recording from the logical analyzer:
The NACK is the problem. According to the datasheet write sequence should be this:
Here is the code. The i2c_init(); happened successfully.
  1. #define     BQ_SLAVE_ADDR               0x12 >> 1
  2. #define     BQ_CHARGE_OPTION_REG                0X12 >> 1
  3. #define     I2C_MASTER_PORT                         I2C_NUM_0
  4. #define     I2C_MASTER_TIMEOUT_MS           300
  5.
  6.
  7. void app_main(void) {
  8.
  9.     ESP_ERROR_CHECK(i2c_init());  //init is OK
  10.
  11.     uint8_t chargeOption[3] = {BQ_CHARGE_OPTION_REG, 0xf9, 0x82};
  12.
  13.     ESP_ERROR_CHECK(
  14.             i2c_master_write_to_device(I2C_MASTER_PORT, BQ_SLAVE_ADDR, chargeOption, 3, I2C_MASTER_TIMEOUT_MS / portTICK_PERIOD_MS));
  15. }
bq24735 datasheet:
https://www.ti.com/lit/ds/symlink/bq247 ... e.com%252F
Does anyone have a soolution to this? Or are there any bq libraries already implemented?
fordmiki
Re: bq24735 I2C communication
Postby fordmiki » Tue Dec 06, 2022 3:41 pm
The problem is in i2c addressing. In this case the slave address has 7 bits and it is needed to be shifted so the write bit is 0. Command registers need not be shifted, but he slave address has to.
Users browsing this forum: No registered users and 176 guests
