Hello, I am trying to get an ESP32 - S2 to record video from a USB camera and save it to an SD card.
I found this in the example projects: https://github.com/espressif/esp-iot-so ... ra_sd_card
and it seemed to work with release/4.4 of the IDF (I couldn't find this documented anywhere - I just tried and failed with a few different versions of the IDF until I stumbled into the right one)
This seemed to suit my needs, but the framerate of stored data is really low. Most of this time is spent on suspending the UVC streaming and restarting the UVC streaming. If I comment out those lines of code, it will work for a few frames, but then it will start failing to write to the SD card (error code 0x108).
I thought this may be an issue with the frame_cb_sdcard() being called before frame_cb_sdcard() of the last iteration has terminated, so I set trigger_threshold = 100 to test that, but it still fails.
For some reason, I cannot write to the SD card while UVC streaming is active.
I would appreciate any insight as to why I can't write to the SD card while the UVC streaming is active, and any workarounds.
ESP32 - S2 USB Camera to SD card
melsharawy
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
- All times are UTC
- Top
- Delete cookies
About Us
Information
