https://docs.espressif.com/projects/esp ... -the-build
I'm not able to understand where exactly these components can be declared, or in which file this should be added.Including components in the build
- By default, every component is included in the build.
- If you set the COMPONENTS variable to a minimal list of components used directly by your project, then the build will expand to also include required components. The full list of components will be:
---- Components mentioned explicitly in COMPONENTS.
---- Those components’ requirements (evaluated recursively).
---- The “common” components that every component depends on.
- Setting COMPONENTS to the minimal list of required components can significantly reduce compile times.
Should it be in the top-level CMakeLists? Should it be a variable to be set like set(COMPONENTS "partition_table;perfmon;protobuf-c; protocomm")?
If there is any open project that uses this feature?
Thank you!
