I've been playing with the t-display touch and it's been going quite well, however it's just stopped displaying - loading the demo touch program has also stopped working. I'm not sure what to try - is there a way to factory reset the board?
-Andrew
Factory reset?
FRANCISCO2020
Re: Factory reset?
To restore the factory board of the t-display touch display, you can follow these steps:
Disconnect the board from the computer and make sure there are no other devices connected to it.
Hold down the RESET button for at least 3 seconds.
Without releasing the RESET button, connect the board to the computer using the USB cable.
Continue to hold the RESET button for another 5 seconds.
Release the RESET button and the board will reset to factory settings.
You may need to install the necessary drivers for the computer to recognize the board again. You may also need to reload the firmware on the board.
Gaurav Shankar
Users browsing this forum: Qwantbot and 3 guests
