Noise on serial line
CarbonMan
Postby CarbonMan » Thu Dec 22, 2022 7:13 pm
I am connecting 2 esp32s together, communication is one-way. The sender is a Makerfab esp32uwb based on the WROOM and the receiver is a WT32-SC01 based on the WROVER.
The sender initializes the connection with
Code: Untitled.cpp Select all
Serial1.begin(9600, SERIAL_8N1, RXD1, TXD1);
where TXD1 is 12
The receiver initializes the connection with
where RXD1 is 13
Grounds are connected.
The connection works, I can send data. However, there is constant noise on the receiver.
I have tried both
pinMode(RXD1, INPUT_PULLUP);
and
pinMode(RXD1, INPUT_PULLDOWN);
on the receiver, but it makes no difference.
I have tried different pins on the sender and the receiver.
Interestingly this did not happen when I used a different board (it was a DEVKIT V1 DOIT I believe) as the sender.
Edit: I have tried changing the sender and receiver to
SERIAL_7E2
but it didn't help.
Any ideas?
username
Re: Noise on serial line
Postby username » Thu Dec 22, 2022 8:02 pm
How long is the serial cable.
CarbonMan
Postby CarbonMan » Thu Dec 22, 2022 9:35 pm
Very short. Maybe 10cm.
Users browsing this forum: Bytespider, ChatGPT-User, PerplexityBot, Qwantbot and 4 guests
