ESP32-S3-EYE_LCD_logo
Yuvaraj1867
Contact:
Postby Yuvaraj1867 » Tue Dec 27, 2022 10:55 am
In ESP32-S3-EYE examples logo_en_240x240_Lcd.h files has the values to display Espressif Logo. The logo is displayed in standalone mode in ESP32-S3-EYE LCD.
Header File: https://github.com/espressif/esp-who/bl ... x240_lcd.h
The header file values are changing between 65355 to 0.
Code: Untitled.c Select all
static const uint16_t logo_en_240x240_lcd[57600] = {65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, ...8213..53456...65535.....etc};
May I know how to convert a JPEG image to this format? I tried some conversions. The converted value is not 65535, it is 255 or 0XFF.
Best Regards,
Dheeran
Aurora
Re: ESP32-S3-EYE_LCD_logo
Postby Aurora » Tue Dec 27, 2022 11:10 am
logo_en_240x240_lcd is in rgb565 format. which is required for lcd display.
you should convert jpeg format to rgb565(16bit element) not to rgb888.
Yuvaraj1867
Contact:
Postby Yuvaraj1867 » Wed Dec 28, 2022 4:46 am
Thanks for the information.
May I know how to convert jpeg format to rgb565(16bit element)? Is there any tool required?
WangYX
Postby WangYX » Fri Dec 30, 2022 8:35 am
Yuvaraj1867
Contact:
Postby Yuvaraj1867 » Fri Jan 13, 2023 9:40 am
Tried but it is not working. Please check the attached log.
void app_main(void)
img_jpeg_decode_test (0,0);
LOG.c
test_camera log details for the default image main/pictures/test_inside.jpeg
(33.87 KiB) Downloaded 1355 times
Yuvaraj1867
Contact:
Postby Yuvaraj1867 » Tue Jan 24, 2023 9:13 am
Any update?
WangYX
Postby WangYX » Sun Jan 29, 2023 2:50 am
To refresh a JPEG image to the LCD in RGB565 format, you need to perform JPEG to RGB565 conversion. This conversion is realized through the `bool jpg2rgb565(const uint8_t *src, size_t src_len, uint8_t * out, jpg_scale_t scale);`. You can print or keep the converted data directly so that the converted RGB565 data can be used directly at the next startup.
WangYX
Postby WangYX » Sun Jan 29, 2023 2:53 am
Of course, you can also provide a JPEG image directly. I will try to test it.
Yuvaraj1867
Contact:
Postby Yuvaraj1867 » Tue Jan 31, 2023 2:58 pm
Please try the attached JPEG image.
JPEG to be converted
WangYX
Postby WangYX » Tue Feb 14, 2023 6:38 am
Here is an example of decoding. Please refer to the example to decode the picture.
jpeg_decode.7z
(21.49 KiB) Downloaded 1493 times
