Hi - I'm developing a PCB that uses nearly all of the available GPIO pins on a WROOM32 module (9 push buttons, a 16x2 LCD display without I2C with PWM pins for brightness and contrast (8 pins in total), an IR receiver, a Tx/Rx serial port - 20 pins in total), so I'm investigating whether I can use the 'Input Only' GPIOs with some of my push buttons. I know that pins 34, 35, 36 and 39 don't have internal pull-up or pull-down resistors, so I have breadboarded my circuit using external pull-up resistors for these pins. I'm using a NodeMCU-32S development board. It seems to work, but I have some questions:
1) What resistor values should I be using? I started off with 100k, but one of the buttons is used for my power switch, and the device powered off fairly randomly, as though the button is being pressed. So I swapped to a 33k resistor value, and the random power-offs happened less frequently, but they still happened. So now I've switched to a 3k9 resistor, and so far this seems to have eliminated the random power-offs. 3k9 seems to be rather a low value (my board will be mains powered, so the odd milliamp of current draw through these pins will not be an issue) - I thought that 33k was already towards the lower end of what's suggested for a pull-up resistor. So am I missing something specific about these pins, or is 3k9 suitable? How low can I go? Could there be something about the NodeMCU-32S board that means these pins behave differently compared to a raw WROOM module?
2) Does the addition of a pull-up resistor turn an 'input only' pin into an 'input/output' pin? Could I use these pins instead as the data pins for my LCD display?
3) Is there anything else I should be aware of regarding these pins?
Chris
Using 'Input Only' GPIOs for push buttons
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: Bytespider, Google [Bot] and 1 guest
- All times are UTC
- Top
- Delete cookies
About Us
Information
