ESP32-S3 without internal or spi flash
Posted: Sat Jan 07, 2023 3:47 am
by sandstorm412
Hello all,
I think I made a mistake and I hope you all have the answer.
I made a custom PCB with a ESP32-S3 IC, I did not add a spi flash...
I realize now that the S3 base model doesn't have any internal flash.
Can I use the ROM?
is there any way I can put code on this? without adding spi flash?
Can I just switch it out with ESP32-S3FH4?
I'm testing with adafruits esp flash tool:
https://adafruit.github.io/Adafruit_WebSerial_ESPTool/
It can not detect the flash size, though I figured it should just say 0 since there is no flash connected.
Detecting Flash Size
FlashId: 0xFFFFFF
Flash Manufacturer: ff
Flash Device: ffff
Auto-detected Flash size: undefined
Any help would be greatly appreciated.
tyia
Re: ESP32-S3 without internal or spi flash
Posted: Sat Jan 07, 2023 6:19 am
by Sprite
No. The ROM is not programmable, and a flash-less ESP32 doesnt' have any other nonvolatile memory it can boot from. Switching out the chip for a S3FH4 will work as long as you are not using the GPIOs that are connected to the internal flash in your circuit design.
Posted: Mon Jan 09, 2023 9:20 am
by Julien1138
I have a similar problem, and I was wondering if there was any way to download my program into RAM ? To at least validate all the ESP32 peripherals on the board.
Thanks for your help.
