ESP-32 keeps resetting
stnmane
Postby stnmane » Sun Jan 22, 2023 4:05 am
Hello everyone
I have a esp32-wroom-32d module that ive been using and programming using ESP-IDF.
Today during a power up, the device stopped working and kept resetting. The error code is the following:
Code: Untitled.txt Select all
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:6992
load:0x40078000,len:15452
load:0x40080400,len:3840
0x40080400: _init at ??:?
entry 0x4008064c
ets Jun 8 2016 00:22:57
Things ive tryed during troubleshooting:
- 3v3 source check using an oscilloscope
- WDT disable during boot
- Flash frequency change
- Flash erase and reflash using the esp tool, writing the app, partition table and bootloader to the appropriate places
- App and bootloader flash using arduino IDE
There were certanly other tests but i cant even remember now.
The error that i posted before happened once or twice during the throubleshooting. The most common thing was even worse because the terminal data was unreadable (like when the uart baud is missconfigured. That behaviour was the most common).
mbratch
Re: ESP-32 keeps resetting
Postby mbratch » Mon Jan 23, 2023 3:49 pm
Was the identical code working previously? Or was anything changed prior to this error appearing?
stnmane
Postby stnmane » Mon Jan 23, 2023 7:24 pm
Hello.
Yes the code was working.
stnmane
Postby stnmane » Tue Jan 24, 2023 12:35 am
Just to add some more information there were a few reflashes of the ESP32 but no changes in functionality. The things that were altered was data inside a buffer that was transmitted through SPI.
Im using HSPI with MISO on 33, MOSI on 13 and CLK on 14. To select the devices im using the ios 12, 25, 26 and 27. I took care to place a pulldown on IO12 as is a strapping pin.
mbratch
Postby mbratch » Thu Jan 26, 2023 12:19 pm
Is that static data in a fixed buffer, or do you mean the code is writing different data (or a different amount of data) to a buffer?
filo_gr
Postby filo_gr » Thu Jan 26, 2023 12:53 pm
I don't know if I can be helpful, however I had similar problems in a project when I switched from a Flash frequency of 40MHz to 80MHz. ESP32 started resetting randomly even with simple code.
Try to remember if you changed something when you flash the chip.
Filippo
Seeker
Postby Seeker » Thu Jan 26, 2023 2:09 pm
When I've seen this issue it has always been caused by 'code run amuck', ie bad pointer, array out of bounds, trying to serial print a float as a char etc etc. Go back to KNOWN good code with KNOWN good data and troubleshoot forward.
bidrohini
Postby bidrohini » Thu Jan 26, 2023 3:36 pm
stnmane
Postby stnmane » Thu Jan 26, 2023 7:26 pm
Yes it is static data in a buffer that is read by the program and written in the spi bus.
There was no change in those settings previous to the error.
Yes, that was my 1st approach, i've uploaded a blink example and the problem continued
mgsecord62
Postby mgsecord62 » Thu Jan 26, 2023 8:24 pm
Have you tried a different esp32-wroom-32d module?
Users browsing this forum: Amazon [Bot] and 2 guests
