My ESP-IDE Eclipse compiler works fine for projects created by me.
But I get another ESP32 Eclipse project from GitHub, it fails when I build the project,
it report Error:
"program "make" not found in PATH",
how to fix it?
Regards
Sam
Build fail for imported existing Eclipse IDF project
Re: Build fail for imported existing Eclipse IDF project
https://github.com/espressif/idf-eclips ... pse-plugin
Could you please check whether the imported project from GitHub is a Make project, if yes then probably you need to convert that into CMake and use it?
Thanks.
IDF Eclipse Plugin or Espressif-IDE only supports ESP-IDF CMake based projects (4.X and above). It doesn't offer support for "Make" projects."program "make" not found in PATH",
Thanks.
There are CMakeList.txt, Makefile and sdkconfig.defaults in the root directory,
The content of CMakeList.txt is:
# The following lines of boilerplate have to be in your project's
# CMakeLists in this exact order for cmake to work correctly
cmake_minimum_required(VERSION 3.5)
idf_build_set_property(C_COMPILE_OPTIONS "-Wno-error=format-truncation" APPEND)
project(RH-RECD-02-01-00)
The content of Makefile is:
PROJECT_NAME := Rheem-CTA2045-UCM
CFLAGS = -Wno-error=format-truncation
include $(IDF_PATH)/make/project.mk
CTA2045_UCM_ROOT_DIR = .
CPPCHECK_SUPPRESSION_LIST_FILE = $(CTA2045_UCM_ROOT_DIR)/.settings/cppcheck_suppression_list.txt
Too many line for sdkconfig.defaults; not copy it.
some settings is not right and cause this error?
Regards
Sam
Regards
Sam
Users browsing this forum: No registered users and 93 guests
