I want to run a shell script on the esp-idf terminal in vs code which contains a command to build and clean using idf.py and some others.
Shell Script doesn't seem to be running on that terminal. It doesn't give any output.
Are there any settings that need to be done?
run a shell script on esp-idf terminal in vs code
Users browsing this forum: Abisha, Google [Bot] and 174 guests
