AP Mode - esp_wifi_set_config throwing error
Amorphous
Postby Amorphous » Sun Feb 05, 2023 5:30 am
Creating a program to start the ESP8266 in AP Mode. But everytime I run it the function esp_wifi_set_config throws an error
Error :
ESP_ERROR_CHECK failed: esp_err_t 0x2 (ERROR) at 0x40220064
0x40220064: _esp_error_check_failed at C:/esp/ESP8266_RTOS_SDK/components/freertos/port/esp8266/panic.c:206
file: "wifi_app.c" line 539
func: wifi_softap_config
expression: esp_wifi_set_config(ESP_IF_WIFI_AP, &ap_config)
abort() was called at PC 0x40220067 on core 0
0x40220067: _esp_error_check_failed at C:/esp/ESP8266_RTOS_SDK/components/freertos/port/esp8266/panic.c:207
Code :
static void wifi_app_event_handler_init(void){
	//Event loop for Wifi driver
	ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_app_event_handler, NULL));
	ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, ESP_EVENT_ANY_ID, &wifi_app_event_handler, NULL));
static void wifi_ap_app_default_wifi_init(void)
	//Initialize TCPIP Stack
	tcpip_adapter_init();
static void wifi_softap_config(void)
	wifi_config_t ap_config =
			.ap = {
					.ssid = WIFI_AP_SSID,
					.ssid_len = MAX_SSID_LENGTH,
					.password = WIFI_AP_PASSWORD,
					.channel = WIFI_AP_CHANNEL,
					.ssid_hidden = WIFI_AP_SSID_HIDDEN,
					.authmode = WIFI_AUTH_WPA2_PSK,
					.max_connection = WIFI_AP_MAX_CONNECTIONS,
					.beacon_interval = WIFI_AP_BEACON_INTERVAL,
	tcpip_adapter_ip_info_t ap_ip_info;
	memset(&ap_ip_info, 0x00, sizeof(ap_ip_info));
	tcpip_adapter_dhcpc_stop(TCPIP_ADAPTER_IF_AP);
	inet_pton(AF_INET, WIFI_AP_IP,&ap_ip_info.ip);
	inet_pton(AF_INET, WIFI_AP_GATEWAY, &ap_ip_info.gw);
	inet_pton(AF_INET, WIFI_AP_NETMASK, &ap_ip_info.netmask);
	tcpip_adapter_set_ip_info(TCPIP_ADAPTER_IF_AP, &ap_ip_info);
	tcpip_adapter_dhcpc_start(TCPIP_ADAPTER_IF_AP);
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
    ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &ap_config)); [b]// THIS LINE IS THROWING ERROR[/b]
static void wifi_ap_app_task(void *pvParameters)
	wifi_app_queue_message_t msg;
	EventBits_t eventBits;
	wifi_app_event_handler_init();
	wifi_ap_app_default_wifi_init();
	wifi_softap_config();
	ESP_ERROR_CHECK(esp_wifi_start());
	wifi_app_send_message(WIFI_AP_SERVER_START);
	while(1)
		if (xQueueReceive(wifi_app_queue_handle, &msg, portMAX_DELAY))
			switch(msg.wifi_message)
			case WIFI_AP_SERVER_START:
				ESP_LOGI(TAG, "352 WIFI_AP_START");
			default:
void wifi_ap_app_start(void)
	ESP_LOGI(TAG,"STARTING WIFI AP APP");
	esp_log_level_set("wifi", ESP_LOG_NONE);
	nvs_flash_init();
	//Initialize GPIO
	gpio_main();
	//CREATE MESSAGE QUEUE
	wifi_app_queue_handle = xQueueCreate(5,sizeof(wifi_app_queue_message_t));
	//Create wifi application event group
	wifi_app_event_group = xEventGroupCreate();
	xTaskCreate(&wifi_ap_app_task, "wifi_ap_app_task", 4096, NULL, 5, NULL);
Can anyone please point to my mistake here?
P32Studio
Re: AP Mode - esp_wifi_set_config throwing error
Postby P32Studio » Fri Jul 07, 2023 10:51 am
Hi, you should run 'esp_netif_init()' prior to calling 'ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler, NULL));' the should fix the problem.
Users browsing this forum: Majestic-12 [Bot] and 220 guests
