ADC input impedance
kostyan5
ADC input impedance
Postby kostyan5 » Sun Oct 01, 2017 6:34 pm
Does anyone know... what is the input impedance of the ADC? Also, what are the resistor values of the attenuator pad?
ayavilevich
Re: ADC input impedance
Postby ayavilevich » Mon Oct 23, 2017 4:56 pm
I am also interested to know this. Wasn't able to find this in the datasheet.
hgptamn
Postby hgptamn » Tue Jan 30, 2018 1:48 pm
I would also like to know that; couldn't find it either!
BuddyCasino
Postby BuddyCasino » Tue Jan 30, 2018 4:02 pm
Suddenly I want to know these things as well, even though I have absolutely no use for this information. I just love drama.
PiMaker
Postby PiMaker » Tue Feb 13, 2018 3:39 pm
Though I don't have any hard values for input impedance since they aren't listed in the spec, it would seem dependent on which ADC you select. SAR ADC1 has a built-in LNA, so you should be able to configure it as a unity gain amplifier which as I'm sure you know will give you extremely low input impedance. The other ADCs don't have this feature so I presume the input impedance will be high like most microcontrollers. If you don't want jitter or slow sample issues, then you need to either use the integrated LNA or use an external op amp to feed the ADC.
longjf
Postby longjf » Tue May 28, 2019 6:41 pm
I just used a voltage divider on the first input two 10K resistors... I observed 2.49 volts on the pin with two 10K resistors splitting the reference in half or so. I get 37K as a nominal impedance....
Tnarain5
Postby Tnarain5 » Wed Jan 01, 2020 6:33 am
Hey, i was using MAX4466 for ADC input but i have a lots of noise in input. i tried adding 0.03uF capacitor but noise still exists.
