compiler options to save memory?
beta-tester
Postby beta-tester » Tue Feb 07, 2023 6:12 am
hi,
i am using Arduino-IDE 1.8.x with espressif/arduino-esp32 (version 2.06).
when i take a look to the bin files it generates, then there are always a bunch of file pathes included that is a waste of memory and it gives an unwanted hint of the environment where it came from (home or user path are included as well).
are there settings in Adruino-IDE where i can prevent the compiler from add those unwanted stuff to the bin file?
the debug option in Arduino-IDE is set to 'none'.
here a hexdump from a random bin file:
$ hd test.bin | grep -E '(IDF)|(Users)|(home)' -B0 -A8
Code: hexdump.txt Select all
00001090  5f 6c 65 6e 20 3c 3d 20  33 32 00 2f 49 44 46 2f  |_len <= 32./IDF/|
000010a0 63 6f 6d 70 6f 6e 65 6e 74 73 2f 62 6f 6f 74 6c |components/bootl|
000010b0 6f 61 64 65 72 5f 73 75 70 70 6f 72 74 2f 73 72 |oader_support/sr|
000010c0 63 2f 62 6f 6f 74 6c 6f 61 64 65 72 5f 66 6c 61 |c/bootloader_fla|
000010d0 73 68 2e 63 00 6d 69 73 6f 5f 6c 65 6e 20 3c 3d |sh.c.miso_len <=|
00001140 74 61 72 74 31 00 2f 49 44 46 2f 63 6f 6d 70 6f |tart1./IDF/compo|
00001150 6e 65 6e 74 73 2f 62 6f 6f 74 6c 6f 61 64 65 72 |nents/bootloader|
00001160 5f 73 75 70 70 6f 72 74 2f 69 6e 63 6c 75 64 65 |_support/include|
00001170 2f 62 6f 6f 74 6c 6f 61 64 65 72 5f 75 74 69 6c |/bootloader_util|
00001180 2e 68 00 65 6e 64 32 3e 73 74 61 72 74 32 00 6c |.h.end2>start2.l|
000011a0 64 64 72 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 |ddr./IDF/compone|
000011b0 6e 74 73 2f 62 6f 6f 74 6c 6f 61 64 65 72 5f 73 |nts/bootloader_s|
000011c0 75 70 70 6f 72 74 2f 73 72 63 2f 65 73 70 5f 69 |upport/src/esp_i|
000011d0 6d 61 67 65 5f 66 6f 72 6d 61 74 2e 63 00 43 61 |mage_format.c.Ca|
00001240 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e 74 73 |./IDF/components|
00001250 2f 62 6f 6f 74 6c 6f 61 64 65 72 5f 73 75 70 70 |/bootloader_supp|
00001260 6f 72 74 2f 73 72 63 2f 65 73 70 33 32 2f 62 6f |ort/src/esp32/bo|
00001270 6f 74 6c 6f 61 64 65 72 5f 73 68 61 2e 63 00 64 |otloader_sha.c.d|
00001360 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e 74 73 2f 62 |IDF/components/b|
00001370 6f 6f 74 6c 6f 61 64 65 72 5f 73 75 70 70 6f 72 |ootloader_suppor|
00001380 74 2f 73 72 63 2f 65 73 70 33 32 2f 62 6f 6f 74 |t/src/esp32/boot|
00001390 6c 6f 61 64 65 72 5f 65 73 70 33 32 2e 63 00 26 |loader_esp32.c.&|
000013f0 66 65 72 20 21 3d 20 4e 55 4c 4c 00 2f 49 44 46 |fer != NULL./IDF|
00001400 2f 63 6f 6d 70 6f 6e 65 6e 74 73 2f 62 6f 6f 74 |/components/boot|
00001410 6c 6f 61 64 65 72 5f 73 75 70 70 6f 72 74 2f 73 |loader_support/s|
00001420 72 63 2f 62 6f 6f 74 6c 6f 61 64 65 72 5f 72 61 |rc/bootloader_ra|
00001430 6e 64 6f 6d 2e 63 00 62 6f 6f 74 6c 6f 61 64 65 |ndom.c.bootloade|
00001460 32 37 36 37 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e |2767./IDF/compon|
00001470 65 6e 74 73 2f 65 73 70 5f 68 77 5f 73 75 70 70 |ents/esp_hw_supp|
00001480 6f 72 74 2f 70 6f 72 74 2f 65 73 70 33 32 2f 72 |ort/port/esp32/r|
00001490 74 63 5f 74 69 6d 65 2e 63 00 72 74 63 5f 63 6c |tc_time.c.rtc_cl|
00010120 43 3a 2f 55 73 65 72 73 2f 6c 65 77 69 73 2f 2e |C:/Users/lewis/.|
00010130 70 6c 61 74 66 6f 72 6d 69 6f 2f 70 61 63 6b 61 |platformio/packa|
00010140 67 65 73 2f 66 72 61 6d 65 77 6f 72 6b 2d 61 72 |ges/framework-ar|
00010150 64 75 69 6e 6f 65 73 70 72 65 73 73 69 66 33 32 |duinoespressif32|
00010160 2f 63 6f 72 65 73 2f 65 73 70 33 32 2f 48 61 72 |/cores/esp32/Har|
00010170 64 77 61 72 65 53 65 72 69 61 6c 2e 63 70 70 00 |dwareSerial.cpp.|
00010630 5f 69 6e 74 72 29 00 43 3a 2f 55 73 65 72 73 2f |_intr).C:/Users/|
00010640 6c 65 77 69 73 2f 2e 70 6c 61 74 66 6f 72 6d 69 |lewis/.platformi|
00010650 6f 2f 70 61 63 6b 61 67 65 73 2f 66 72 61 6d 65 |o/packages/frame|
00010660 77 6f 72 6b 2d 61 72 64 75 69 6e 6f 65 73 70 72 |work-arduinoespr|
00010670 65 73 73 69 66 33 32 2f 63 6f 72 65 73 2f 65 73 |essif32/cores/es|
00010680 70 33 32 2f 65 73 70 33 32 2d 68 61 6c 2d 75 61 |p32/esp32-hal-ua|
00010690 72 74 2e 63 00 75 61 72 74 5f 66 6c 75 73 68 5f |rt.c.uart_flush_|
00010b40 29 29 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e |))./IDF/componen|
00010b50 74 73 2f 68 61 6c 2f 65 73 70 33 32 2f 69 6e 63 |ts/hal/esp32/inc|
00010b60 6c 75 64 65 2f 68 61 6c 2f 67 70 69 6f 5f 6c 6c |lude/hal/gpio_ll|
00010b70 2e 68 00 22 28 43 61 6e 6e 6f 74 20 75 73 65 20 |.h."(Cannot use |
00010f20 4c 4c 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e |LL./IDF/componen|
00010f30 74 73 2f 64 72 69 76 65 72 2f 67 70 69 6f 2e 63 |ts/driver/gpio.c|
00011350 33 46 46 43 29 29 00 2f 49 44 46 2f 63 6f 6d 70 |3FFC))./IDF/comp|
00011360 6f 6e 65 6e 74 73 2f 68 61 6c 2f 65 73 70 33 32 |onents/hal/esp32|
00011370 2f 69 6e 63 6c 75 64 65 2f 68 61 6c 2f 72 74 63 |/include/hal/rtc|
00011380 5f 69 6f 5f 6c 6c 2e 68 00 22 28 43 61 6e 6e 6f |_io_ll.h."(Canno|
00011ad0 4c 45 5f 4d 41 58 00 2f 49 44 46 2f 63 6f 6d 70 |LE_MAX./IDF/comp|
00011ae0 6f 6e 65 6e 74 73 2f 64 72 69 76 65 72 2f 70 65 |onents/driver/pe|
00011af0 72 69 70 68 5f 63 74 72 6c 2e 63 00 70 65 72 69 |riph_ctrl.c.peri|
00011bb0 5f 46 41 49 4c 00 2f 49 44 46 2f 63 6f 6d 70 6f |_FAIL./IDF/compo|
00011bc0 6e 65 6e 74 73 2f 61 70 70 5f 75 70 64 61 74 65 |nents/app_update|
00011bd0 2f 65 73 70 5f 6f 74 61 5f 6f 70 73 2e 63 00 69 |/esp_ota_ops.c.i|
00011d90 5f 6c 65 6e 20 3c 3d 20 33 32 00 2f 49 44 46 2f |_len <= 32./IDF/|
00011da0 63 6f 6d 70 6f 6e 65 6e 74 73 2f 62 6f 6f 74 6c |components/bootl|
00011db0 6f 61 64 65 72 5f 73 75 70 70 6f 72 74 2f 73 72 |oader_support/sr|
00011dc0 63 2f 62 6f 6f 74 6c 6f 61 64 65 72 5f 66 6c 61 |c/bootloader_fla|
00011dd0 73 68 2e 63 00 6d 69 73 6f 5f 6c 65 6e 20 3c 3d |sh.c.miso_len <=|
00012110 4c 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e 74 |L./IDF/component|
00012120 73 2f 62 6f 6f 74 6c 6f 61 64 65 72 5f 73 75 70 |s/bootloader_sup|
00012130 70 6f 72 74 2f 73 72 63 2f 69 64 66 2f 62 6f 6f |port/src/idf/boo|
00012140 74 6c 6f 61 64 65 72 5f 73 68 61 2e 63 00 72 65 |tloader_sha.c.re|
00012210 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e 74 73 2f |/IDF/components/|
00012220 73 70 69 5f 66 6c 61 73 68 2f 70 61 72 74 69 74 |spi_flash/partit|
00012230 69 6f 6e 2e 63 00 69 74 65 72 61 74 6f 72 20 21 |ion.c.iterator !|
00012380 67 65 6e 6f 5d 29 20 29 00 2f 49 44 46 2f 63 6f |geno]) )./IDF/co|
00012390 6d 70 6f 6e 65 6e 74 73 2f 73 70 69 5f 66 6c 61 |mponents/spi_fla|
000123a0 73 68 2f 66 6c 61 73 68 5f 6d 6d 61 70 2e 63 00 |sh/flash_mmap.c.|
00012480 69 6e 20 3c 20 6c 65 6e 00 2f 49 44 46 2f 63 6f |in < len./IDF/co|
00012490 6d 70 6f 6e 65 6e 74 73 2f 73 70 69 5f 66 6c 61 |mponents/spi_fla|
000124a0 73 68 2f 65 73 70 5f 66 6c 61 73 68 5f 61 70 69 |sh/esp_flash_api|
000124b0 2e 63 00 6c 65 6e 5f 72 65 6d 61 69 6e 20 3c 20 |.c.len_remain < |
00012620 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e 74 73 |./IDF/components|
00012630 2f 73 70 69 5f 66 6c 61 73 68 2f 73 70 69 5f 66 |/spi_flash/spi_f|
00012640 6c 61 73 68 5f 6f 73 5f 66 75 6e 63 5f 61 70 70 |lash_os_func_app|
00012650 2e 63 00 73 70 69 31 5f 66 6c 61 73 68 5f 6f 73 |.c.spi1_flash_os|
00012680 20 4e 55 4c 4c 00 2f 49 44 46 2f 63 6f 6d 70 6f | NULL./IDF/compo|
00012690 6e 65 6e 74 73 2f 73 70 69 5f 66 6c 61 73 68 2f |nents/spi_flash/|
000126a0 63 61 63 68 65 5f 75 74 69 6c 73 2e 63 00 65 73 |cache_utils.c.es|
000128a0 71 4e 6f 29 00 49 44 46 2f 63 6f 6d 70 6f 6e 65 |qNo).IDF/compone|
000128b0 6e 74 73 2f 6e 76 73 5f 66 6c 61 73 68 2f 73 72 |nts/nvs_flash/sr|
000128c0 63 2f 6e 76 73 5f 70 61 67 65 6d 61 6e 61 67 65 |c/nvs_pagemanage|
000128d0 72 2e 63 70 70 00 65 73 70 5f 65 72 72 5f 74 20 |r.cpp.esp_err_t |
000129c0 69 73 74 21 22 00 2f 49 44 46 2f 63 6f 6d 70 6f |ist!"./IDF/compo|
000129d0 6e 65 6e 74 73 2f 70 74 68 72 65 61 64 2f 70 74 |nents/pthread/pt|
000129e0 68 72 65 61 64 2e 63 00 45 20 28 25 75 29 20 25 |hread.c.E (%u) %|
00012a90 55 4c 4c 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 |ULL./IDF/compone|
00012aa0 6e 74 73 2f 70 74 68 72 65 61 64 2f 70 74 68 72 |nts/pthread/pthr|
00012ab0 65 61 64 5f 6c 6f 63 61 6c 5f 73 74 6f 72 61 67 |ead_local_storag|
00012ac0 65 2e 63 00 70 74 68 72 65 61 64 5f 6c 6f 63 61 |e.c.pthread_loca|
00012c80 72 5f 68 61 6e 64 6c 65 29 00 49 44 46 2f 63 6f |r_handle).IDF/co|
00012c90 6d 70 6f 6e 65 6e 74 73 2f 65 73 70 5f 73 79 73 |mponents/esp_sys|
00012ca0 74 65 6d 2f 74 61 73 6b 5f 77 64 74 2e 63 00 65 |tem/task_wdt.c.e|
00012de0 5f 46 52 45 51 5f 41 55 54 4f 00 2f 49 44 46 2f |_FREQ_AUTO./IDF/|
00012df0 63 6f 6d 70 6f 6e 65 6e 74 73 2f 65 73 70 5f 73 |components/esp_s|
00012e00 79 73 74 65 6d 2f 70 6f 72 74 2f 73 6f 63 2f 65 |ystem/port/soc/e|
00012e10 73 70 33 32 2f 63 6c 6b 2e 63 00 72 65 73 00 00 |sp32/clk.c.res..|
00012e50 30 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e 74 |0./IDF/component|
00012e60 73 2f 65 73 70 5f 73 79 73 74 65 6d 2f 70 6f 72 |s/esp_system/por|
00012e70 74 2f 73 6f 63 2f 65 73 70 33 32 2f 72 65 73 65 |t/soc/esp32/rese|
00012e80 74 5f 72 65 61 73 6f 6e 2e 63 00 65 73 70 5f 72 |t_reason.c.esp_r|
00012f10 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e 74 73 2f |/IDF/components/|
00012f20 65 73 70 5f 73 79 73 74 65 6d 2f 63 72 6f 73 73 |esp_system/cross|
00012f30 63 6f 72 65 5f 69 6e 74 2e 63 00 65 72 72 00 65 |core_int.c.err.e|
00013030 65 22 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e |e"./IDF/componen|
00013040 74 73 2f 65 73 70 5f 73 79 73 74 65 6d 2f 73 74 |ts/esp_system/st|
00013050 61 72 74 75 70 2e 63 00 2f 64 65 76 2f 63 6f 6e |artup.c./dev/con|
00013720 20 30 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e | 0./IDF/componen|
00013730 74 73 2f 76 66 73 2f 76 66 73 2e 63 00 74 72 61 |ts/vfs/vfs.c.tra|
00013a20 61 72 74 29 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e |art)./IDF/compon|
00013a30 65 6e 74 73 2f 68 65 61 70 2f 68 65 61 70 5f 63 |ents/heap/heap_c|
00013a40 61 70 73 2e 63 00 65 73 70 5f 70 74 72 5f 69 6e |aps.c.esp_ptr_in|
00013bc0 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e 74 73 2f |/IDF/components/|
00013bd0 68 65 61 70 2f 68 65 61 70 5f 63 61 70 73 5f 69 |heap/heap_caps_i|
00013be0 6e 69 74 2e 63 00 68 65 61 70 5f 69 64 78 20 3c |nit.c.heap_idx <|
00013c80 69 5d 2e 65 6e 64 00 2f 49 44 46 2f 63 6f 6d 70 |i].end./IDF/comp|
00013c90 6f 6e 65 6e 74 73 2f 68 65 61 70 2f 70 6f 72 74 |onents/heap/port|
00013ca0 2f 6d 65 6d 6f 72 79 5f 6c 61 79 6f 75 74 5f 75 |/memory_layout_u|
00013cb0 74 69 6c 73 2e 63 00 72 65 73 65 72 76 65 64 5b |tils.c.reserved[|
000148c0 4f 4e 53 48 41 52 45 44 29 29 00 2f 49 44 46 2f |ONSHARED))./IDF/|
000148d0 63 6f 6d 70 6f 6e 65 6e 74 73 2f 65 73 70 5f 68 |components/esp_h|
000148e0 77 5f 73 75 70 70 6f 72 74 2f 69 6e 74 72 5f 61 |w_support/intr_a|
000148f0 6c 6c 6f 63 2e 63 00 73 76 64 20 21 3d 20 4e 55 |lloc.c.svd != NU|
00014960 33 32 37 36 37 00 2f 49 44 46 2f 63 6f 6d 70 6f |32767./IDF/compo|
00014970 6e 65 6e 74 73 2f 65 73 70 5f 68 77 5f 73 75 70 |nents/esp_hw_sup|
00014980 70 6f 72 74 2f 70 6f 72 74 2f 65 73 70 33 32 2f |port/port/esp32/|
00014990 72 74 63 5f 74 69 6d 65 2e 63 00 72 74 63 5f 74 |rtc_time.c.rtc_t|
000167a0 65 64 28 70 74 69 6d 65 72 29 00 2f 49 44 46 2f |ed(ptimer)./IDF/|
000167b0 63 6f 6d 70 6f 6e 65 6e 74 73 2f 65 73 70 5f 74 |components/esp_t|
000167c0 69 6d 65 72 2f 73 72 63 2f 65 74 73 5f 74 69 6d |imer/src/ets_tim|
000167d0 65 72 5f 6c 65 67 61 63 79 2e 63 00 65 73 70 5f |er_legacy.c.esp_|
00016890 6f 77 22 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 |ow"./IDF/compone|
000168a0 6e 74 73 2f 65 73 70 5f 74 69 6d 65 72 2f 73 72 |nts/esp_timer/sr|
000168b0 63 2f 65 73 70 5f 74 69 6d 65 72 5f 69 6d 70 6c |c/esp_timer_impl|
000168c0 5f 6c 61 63 2e 63 00 61 70 62 5f 74 69 63 6b 73 |_lac.c.apb_ticks|
00016a10 00 00 00 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 |..../IDF/compone|
00016a20 6e 74 73 2f 65 73 70 5f 68 77 5f 73 75 70 70 6f |nts/esp_hw_suppo|
00016a30 72 74 2f 69 6e 63 6c 75 64 65 2f 73 6f 63 2f 73 |rt/include/soc/s|
00016a40 70 69 6e 6c 6f 63 6b 2e 68 00 00 00 72 65 73 75 |pinlock.h...resu|
00016be0 70 64 54 52 55 45 00 2f 49 44 46 2f 63 6f 6d 70 |pdTRUE./IDF/comp|
00016bf0 6f 6e 65 6e 74 73 2f 66 72 65 65 72 74 6f 73 2f |onents/freertos/|
00016c00 70 6f 72 74 2f 70 6f 72 74 5f 63 6f 6d 6d 6f 6e |port/port_common|
00016c10 2e 63 00 70 78 54 43 42 42 75 66 66 65 72 54 65 |.c.pxTCBBufferTe|
000172e0 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e 74 73 |./IDF/components|
000172f0 2f 66 72 65 65 72 74 6f 73 2f 74 61 73 6b 73 2e |/freertos/tasks.|
00017300 63 00 70 78 54 43 42 2d 3e 75 63 53 74 61 74 69 |c.pxTCB->ucStati|
00017840 30 29 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 6e |0)./IDF/componen|
00017850 74 73 2f 6e 65 77 6c 69 62 2f 6c 6f 63 6b 73 2e |ts/newlib/locks.|
00017860 63 00 6c 6f 63 6b 20 21 3d 20 4e 55 4c 4c 20 26 |c.lock != NULL &|
000179a0 2c 20 6d 65 6d 5f 65 6e 64 29 00 49 44 46 2f 63 |, mem_end).IDF/c|
000179b0 6f 6d 70 6f 6e 65 6e 74 73 2f 62 74 2f 63 6f 6e |omponents/bt/con|
000179c0 74 72 6f 6c 6c 65 72 2f 65 73 70 33 32 2f 62 74 |troller/esp32/bt|
000179d0 2e 63 00 65 73 70 5f 62 74 5f 63 6f 6e 74 72 6f |.c.esp_bt_contro|
00017a80 20 34 20 29 29 29 00 2f 49 44 46 2f 63 6f 6d 70 | 4 )))./IDF/comp|
00017a90 6f 6e 65 6e 74 73 2f 65 73 70 5f 72 69 6e 67 62 |onents/esp_ringb|
00017aa0 75 66 2f 72 69 6e 67 62 75 66 2e 63 00 70 78 52 |uf/ringbuf.c.pxR|
000182e0 4d 41 58 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e 65 |MAX./IDF/compone|
000182f0 6e 74 73 2f 65 66 75 73 65 2f 73 72 63 2f 65 73 |nts/efuse/src/es|
00018300 70 5f 65 66 75 73 65 5f 75 74 69 6c 69 74 79 2e |p_efuse_utility.|
00018310 63 00 6e 75 6d 5f 72 65 67 20 3c 3d 20 28 72 61 |c.num_reg <= (ra|
00018570 72 65 49 44 28 29 00 2f 49 44 46 2f 63 6f 6d 70 |reID()./IDF/comp|
00018580 6f 6e 65 6e 74 73 2f 65 73 70 5f 69 70 63 2f 73 |onents/esp_ipc/s|
00018590 72 63 2f 65 73 70 5f 69 70 63 2e 63 00 69 70 63 |rc/esp_ipc.c.ipc|
000185b0 69 70 63 5f 69 6e 69 74 00 2f 49 44 46 2f 63 6f |ipc_init./IDF/co|
000185c0 6d 70 6f 6e 65 6e 74 73 2f 65 73 70 5f 69 70 63 |mponents/esp_ipc|
000185d0 2f 73 72 63 2f 65 73 70 5f 69 70 63 5f 69 73 72 |/src/esp_ipc_isr|
000185e0 2f 65 73 70 5f 69 70 63 5f 69 73 72 2e 63 00 65 |/esp_ipc_isr.c.e|
00018980 3d 20 4e 55 4c 4c 00 2f 49 44 46 2f 63 6f 6d 70 |= NULL./IDF/comp|
00018990 6f 6e 65 6e 74 73 2f 6d 62 65 64 74 6c 73 2f 70 |onents/mbedtls/p|
000189a0 6f 72 74 2f 73 68 61 2f 70 61 72 61 6c 6c 65 6c |ort/sha/parallel|
000189b0 5f 65 6e 67 69 6e 65 2f 73 68 61 2e 63 00 65 6e |_engine/sha.c.en|
0001ebb0 65 63 74 22 00 2f 49 44 46 2f 63 6f 6d 70 6f 6e |ect"./IDF/compon|
0001ebc0 65 6e 74 73 2f 68 65 61 70 2f 68 65 61 70 5f 74 |ents/heap/heap_t|
0001ebd0 6c 73 66 2e 63 00 73 69 7a 65 20 3d 3d 20 74 68 |lsf.c.size == th|
0001f200 74 61 72 74 5f 70 74 72 00 2f 49 44 46 2f 63 6f |tart_ptr./IDF/co|
0001f210 6d 70 6f 6e 65 6e 74 73 2f 68 65 61 70 2f 6d 75 |mponents/heap/mu|
0001f220 6c 74 69 5f 68 65 61 70 2e 63 00 68 65 61 70 20 |lti_heap.c.heap |
0001f2e0 64 20 21 3d 20 4e 55 4c 4c 00 2f 49 44 46 2f 63 |d != NULL./IDF/c|
0001f2f0 6f 6d 70 6f 6e 65 6e 74 73 2f 68 65 61 70 2f 6d |omponents/heap/m|
0001f300 75 6c 74 69 5f 68 65 61 70 5f 70 6f 69 73 6f 6e |ulti_heap_poison|
0001f310 69 6e 67 2e 63 00 6d 75 6c 74 69 5f 68 65 61 70 |ing.c.multi_heap|
Users browsing this forum: Qwantbot, YisouSpider and 1 guest
