voip例程,按play键无法接听
Posted: Thu Feb 09, 2023 7:21 am
by dodo55
esp-adf-v2.4.1
esp-idf-v4.4.3
ESP32-LyraT V4.3
Freeswitch 服务器
MicroSIP客户端
如果是ESP32-LyraT V4.3呼出,MicroSIP接听,可以正常接通并通话
但如果是MicroSIP呼出,ESP32-LyraT V4.3可以收到电话呼入,也有振铃响声,但是按play键后,MicroSIP显示已接通,但是ESP32-LyraT V4.3还是一直显示有来电呼入,一直振铃,MicroSIP和ESP32-LyraT V4.3均没有任何声音。
以下是ESP32-LyraT V4.3有电话呼入log。
请问哪里的问题?
顺便问问,esp-adf如何设置使用内置的esp-idf?
I (35480) ESP_AUDIO_CTRL: Func:_ctrl_play, Line:775, MEM Total:4255519 Bytes, Inter:241331 Bytes, Dram:202319 Bytes
I (35490) ESP_AUDIO_TASK: It's a decoder
I (35500) ESP_AUDIO_TASK: 1.CUR IN:[IN_flash],CODEC:[DEC_mp3],RESAMPLE:[8000],OUT:[OUT_iis],rate:0,ch:0,pos:0
I (35510) ESP_AUDIO_TASK: 2.Handles,IN:0x3f804f14,CODEC:0x3f8050a4,FILTER:0x3f8144bc,OUT:0x3f805250
I (35520) AUDIO_PIPELINE: audio_pipeline_unlinked
W (35520) AUDIO_PIPELINE: There are no listener registered
I (35530) ESP_AUDIO_TASK: 2.2 Update all pipeline
I (35530) ESP_AUDIO_TASK: 2.3 Linked new pipeline
I (35540) AUDIO_PIPELINE: link el->rb, el:0x3f804f14, tag:IN_flash, rb:0x3f814aa8
I (35550) AUDIO_PIPELINE: link el->rb, el:0x3f8050a4, tag:DEC_mp3, rb:0x3f81480c
I (35560) AUDIO_PIPELINE: link el->rb, el:0x3f8144bc, tag:Audio_forge, rb:0x3f814848
I (35560) ESP_AUDIO_TASK: 3. Previous starting...
I (35570) AUDIO_ELEMENT: [IN_flash-0x3f804f14] Element task created
I (35580) AUDIO_ELEMENT: [IN_flash] AEL_MSG_CMD_RESUME,state:1
I (35580) AUDIO_THREAD: The DEC_mp3 task allocate stack on external memory
I (35580) TONE_PARTITION: tone partition format 0, total 21
I (35590) AUDIO_ELEMENT: [DEC_mp3-0x3f8050a4] Element task created
I (35600) TONE_STREAM: Tone offset:00020c78, Tone length:36018, pos:8
I (35600) AUDIO_ELEMENT: [DEC_mp3] AEL_MSG_CMD_RESUME,state:1
I (35620) MP3_DECODER: MP3 opened
I (35620) ESP_AUDIO_TASK: Blocking play until received AEL_MSG_CMD_REPORT_MUSIC_INFO
I (35630) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (35640) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (35720) ESP_AUDIO_TASK: Received muisc info then on play
I (35720) ESP_AUDIO_TASK: On event play, status:UNKNOWN, 0
I (35720) AUDIO_THREAD: The Audio_forge task allocate stack on external memory
I (35730) AUDIO_ELEMENT: [Audio_forge-0x3f8144bc] Element task created
I (35740) AUDIO_ELEMENT: [Audio_forge] AEL_MSG_CMD_RESUME,state:1
I (35740) AUDIO_FORGE: audio_forge opened
I (35740) AUDIO_THREAD: The OUT_iis task allocate stack on external memory
I (35760) AUDIO_ELEMENT: [OUT_iis-0x3f805250] Element task created
I (35760) AUDIO_ELEMENT: [OUT_iis] AEL_MSG_CMD_RESUME,state:1
I (3570) I2S_STREAM: AUDIO_STREAM_WRITER
I (35770) ESP_AUDIO_CTRL: Exit play procedure, ret:0
I (35780) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (35780) AUDIO_FORGE: audio_forge reopen
I (35790) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (35810) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_RUNNING, 0, src:0, is_stopping:0
I (35820) ESP_AUDIO_TASK: Func:media_ctrl_task, Line:1030, MEM Total:3873251 Bytes, Inter:210687 Bytes, Dram:171675 Bytes
I (36480) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (36480) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (36480) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
W (37400) TONE_STREAM: No more data,ret:0 ,info.byte_pos:36018
I (37400) AUDIO_ELEMENT: IN-[IN_flash] AEL_IO_DONE,0
I (37400) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (37480) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (37480) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (37480) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
I (38290) AUDIO_ELEMENT: IN-[DEC_mp3] AEL_IO_DONE,-2
I (38480) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (38480) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (38480) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
I (38490) MP3_DECODER: Closed
I (38490) ESP_AUDIO_TASK: Received last pos: 36018 bytes
I (38490) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (38600) AUDIO_ELEMENT: IN-[Audio_forge] AEL_IO_DONE,-2
I (38600) AUDIO_FORGE: audio forge closed
I (38600) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (38890) AUDIO_ELEMENT: IN-[OUT_iis] AEL_IO_DONE,-2
I (39110) ESP_AUDIO_TASK: Received last time: 3040 ms
I (39110) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (39120) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_FINISHED, 0, src:0, is_stopping:0
I (39130) ESP_AUDIO_TASK: Func:media_ctrl_task, Line:1030, MEM Total:4227979 Bytes, Inter:236863 Bytes, Dram:197851 Bytes
W (39140) ESP_AUDIO_TASK: Destroy the old pipeline, FINISHED
W (39150) ESP_AUDIO_TASK: The old pipeline destroyed, FINISHED
I (39480) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (39480) ESP_AUDIO_CTRL: Enter play procedure, src:0
I (39480) ESP_AUDIO_CTRL: Play procedure, URL is ok, src:0
I (39480) ESP_AUDIO_CTRL: Request_CMD_Queue CMD:0, Available:5, que:0x3ffc3ad4
I (39490) ESP_AUDIO_CTRL: Func:_ctrl_play, Line:775, MEM Total:4255507 Bytes, Inter:241331 Bytes, Dram:202319 Bytes
I (39500) ESP_AUDIO_TASK: It's a decoder
I (39510) ESP_AUDIO_TASK: 1.CUR IN:[IN_flash],CODEC:[DEC_mp3],RESAMPLE:[8000],OUT:[OUT_iis],rate:0,ch:0,pos:0
I (39520) ESP_AUDIO_TASK: 2.Handles,IN:0x3f804f14,CODEC:0x3f8050a4,FILTER:0x3f8144bc,OUT:0x3f805250
I (39530) AUDIO_PIPELINE: audio_pipeline_unlinked
W (39530) AUDIO_PIPELINE: There are no listener registered
I (39540) ESP_AUDIO_TASK: 2.2 Update all pipeline
I (39540) ESP_AUDIO_TASK: 2.3 Linked new pipeline
I (39550) AUDIO_PIPELINE: link el->rb, el:0x3f804f14, tag:IN_flash, rb:0x3f814aa8
I (39560) AUDIO_PIPELINE: link el->rb, el:0x3f8050a4, tag:DEC_mp3, rb:0x3f81480c
I (39570) AUDIO_PIPELINE: link el->rb, el:0x3f8144bc, tag:Audio_forge, rb:0x3f814848
I (39570) ESP_AUDIO_TASK: 3. Previous starting...
I (39580) AUDIO_ELEMENT: [IN_flash-0x3f804f14] Element task created
I (39590) AUDIO_ELEMENT: [IN_flash] AEL_MSG_CMD_RESUME,state:1
I (39590) AUDIO_THREAD: The DEC_mp3 task allocate stack on external memory
I (39590) TONE_PARTITION: tone partition format 0, total 21
I (39600) AUDIO_ELEMENT: [DEC_mp3-0x3f8050a4] Element task created
I (39610) TONE_STREAM: Tone offset:00020c78, Tone length:36018, pos:8
I (39610) AUDIO_ELEMENT: [DEC_mp3] AEL_MSG_CMD_RESUME,state:1
I (39630) MP3_DECODER: MP3 opened
I (39630) ESP_AUDIO_TASK: Blocking play until received AEL_MSG_CMD_REPORT_MUSIC_INFO
I (39640) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (39650) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (39730) ESP_AUDIO_TASK: Received muisc info then on play
I (39730) ESP_AUDIO_TASK: On event play, status:UNKNOWN, 0
I (39730) AUDIO_THREAD: The Audio_forge task allocate stack on external memory
I (39740) AUDIO_ELEMENT: [Audio_forge-0x3f8144bc] Element task created
I (39740) AUDIO_ELEMENT: [Audio_forge] AEL_MSG_CMD_RESUM,state:1
I (39750) AUDIO_FORGE: audio_forge opened
I (39750) AUDIO_THREAD: The OUT_iis task allocate stack on external memory
I (39760) AUDIO_ELEMENT: [OUT_iis-0x3f805250] Element task created
I (39770) AUDIO_ELEMENT: [OUT_iis] AEL_MSG_CMD_RESUME,state:1
I (39780) I2S_STREAM: AUDIO_STREAM_WRITER
I (39780) ESP_AUDIO_CTRL: Exit play procedure, ret:0
I (39790) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (39800) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (39810) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_RUNNING, 0, src:0, is_stopping:0
I (39820) ESP_AUDIO_TASK: Func:media_ctrl_task, Line:1030, MEM Total:3873251 Bytes, Inter:210687 Bytes, Dram:171675 Bytes
I (40240) VOIP_EXAMPLE: [ * ] [Play] input key event
I (40240) ESP_AUDIO_CTRL: Enter media_ctrl_stop procedure, sc:0, type:0, st:RUNNING, phase:4
I (4040) ESP_AUDIO_CTRL: media_ctrl_stop, type:0, st:RUNNING, block_playing:1, MEDIA_CTRL_PHASE_WAIT_RUNNING
I (40260) ESP_AUDIO_CTRL: media_ctrl_stop, src:0, type:0, st:RUNNING, phase:4
I (40260) ESP_AUDIO_CTRL: Request_CMD_Queue CMD:2, Available:5, que:0x3ffc3ad4
I (40270) ESP_AUDIO_TASK: MEDIA_CTRL_EVT_STOP, status:RUNNING
W (40270) AUDIO_ELEMENT: OUT-[DEC_mp3] AEL_IO_ABORT
W (40280) MP3_DECODER: outut aborted -3
I (40280) MP3_DECODER: Closed
W (40290) AUDIELEMENT: OUT-[Audio_forge] AEL_IO_ABORT
I (40290) AUDIO_FORGE: audio forge closed
W (40300) AUDIO_ELEMENT: OUT-[IN_flash] AEL_IO_ABORT
I (40410) ESP_AUDIO_TASK: MEDIA_CTRL_EVT_STOP Done, dat:0
I (40420) ESP_AUDIO_TASK: Received last pos: 11233 bytes
I (40420) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
I (40430) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
I (40440) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
I (40450) ESP_AUDIO_TASK: Received last time: 448 ms
I (40460) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
I (40470) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_STOPPED, 0, src:0, is_stopping:1
I (40480) ESP_AUDIO_TASK: Func:media_ctrl_task, Line:1030, MEM Total:4227975 Bytes, Inter:236863 Bytes, Dram:197851 Bytes
I (40490) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (40490) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (40500) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
W (40510) ESP_AUDIO_TASK: Destroy the old pipeline, STOPPED
W (40510) ESP_AUDIO_TASK: The old pipeline destroyed, STOPPED
I (40520) ESP_AUDIO_TASK: Release the seeking process due to stopping
I (40520) ESP_AUDIO_CTRL: Exit media_ctrl_stop procedure, ret:0
I (40530) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
I (40610) SIP: [1970-01-01/00:00:19]=======WRITE 0603 bytes>>
I (40610) SIP:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 192.168.2.55;branch=z9hG4bKta5N5ac0g6y2D
Contact: <sip:1001@192.168.2.99:64152>
From: "Extension 1000" <sip:1000@192.168.2.55>;tag=F6XUN4QyeN9Br
To: <sip:1001@192.168.2.99:64152;transport=TCP>;tag=1275716600
Call-ID: 39df6c7f-22eb-123c-3f96-11167911e9b9
CSeq: 63409426 INVITE
Server: ESP32 SIP/2.0
Allow: ACK, INVITE, BYE, UPDATE, CANCEL, OPTIONS, INFO
Content-Length: 155
Content-Type: application/sdp
v=0
o=Z 0 3 IN IP4 192.168.2.99
s=Z
c=IN IP4 192.168.2.99
t=0 0
m=audio 35224 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
I (40660) SIP: [1970-01-01/00:00:19]=======================>>
I (41570) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (41570) ESP_AUDIO_CTRL: Enter play procedure, src:0
I (41570) ESP_AUDIO_CTRL: Play procedure, URL is ok, src:0
I (41570) ESP_AUDIO_CTRL: Request_CMD_Queue CMD:0, Available:5, que:0x3ffc3ad4
I (41580) ESP_AUDIO_CTRL: Func:_ctrl_play, Line:775, MEM Total:4255507 Bytes, Inter:241331 Bytes, Dram:202319 Bytes
I (41590) ESP_AUDIO_TASK: It's a decoder
I (41600) ESP_AUDIO_TASK: 1.CUR IN:[IN_flash],CODEC:[DEC_mp3],RESAMPLE:[8000],OUT:[OUT_iis],rate:0,ch:0,pos:0
I (41610) ESP_AUDIO_TASK: 2.Handles,IN:0x3f804f14,CODEC:0x3f8050a4,FILTER:0x3f8144bc,OUT:0x3f805250
W (41620) AUDIO_PIPELINE: Without stop, st:1
W (41620) AUDIO_PIPELINE: Without wait stop, st:1
I (41630) AUDIO_PIPELINE: audio_pipeline_unlinked
W (41630) AUDIO_PIPELINE: There are no listener registered
I (41640) ESP_AUDIO_TASK: 2.2 Update all pipeline
I (41640) ESP_AUDIO_TASK: 2.3 Linked new pipeline
I (41650) AUDIO_PIPELINE: link el->rb, el:0x3f804f14, tag:IN_flash, rb:0x3f814aa8
I (41660) AUDIO_PIPELINE: link el->rb, el:0x3f8050a4, tag:DEC_mp3, rb:0x3f81480c
I (41670) AUDIO_PIPELINE: link el->rb, el:0x3f8144bc, tag:Audio_forge, rb:0x3f814848
I (41670) ESP_AUDIO_TASK: 3. Previous starting...
I (41680) AUDIO_ELEMENT: [IN_flash-0x3f804f14] Element task created
I (41690) AUDIO_ELEMENT: [IN_flash] AEL_MSGCMD_RESUME,state:1
I (41690) AUDIO_THREAD: The DEC_mp3 task allocate stack on external memory
I (41690) TONE_PARTITION: tone partition format 0, total 21
I (41700) AUDIO_ELEMENT: [DEC_mp3-0x3f8050a4] Element task created
I (41710) TONE_STREAM: Tone offset:00020c78, Tone length:36018, pos:8
I (41710) AUDIO_ELEMENT: [DEC_mp3] AEL_MSG_CMD_RESUME,state:1
I (41730) MP3_DECODER: MP3 opened
I (41730) ESP_AUDIO_TASK: Blocking play until received AEL_MSG_CMD_REPORT_MUSIC_INFO
I (41740) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (41750) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (41830) ESP_AUDIO_TASK: Received muisc info then on play
I (41840) ESP_AUDIO_TASK: On event play, status:UNKNOWN, 0
I (41840) AUDIO_THREAD: The Audio_forge task allocate stack on external memory
I (41840) AUDIO_ELEMENT: [Audio_forge-0x3f8144bc] Element task created
I (41850) AUDIO_ELEMENT: [Audio_forge] AEL_MSG_CMD_RESUME,state:1
I (41860) AUDIO_FORGE: audio_forge opened
I (41860) AUDIO_THREAD: The OUT_iis task allocate stack on external memory
I (41870) AUDIO_ELEMENT: [OUT_iis-0x3f805250] Element task created
I (41880) AUDIO_ELEMENT: [OUT_iis] AEL_MSG_CMD_RESUME,state:1
I (41880) I2S_STREAM: AUDIO_STREAM_WRITER
I (41880) ESP_AUDIO_CTRL: Exit play procedure, ret:0
I (41890) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (41910) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (41920) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_RUNNING, 0, src:0, is_stopping:0
I (41930) ESP_AUDIO_TASK: Func:media_ctrl_task, Line:1030, MEM Total:3873251 Bytes, Inter:210687 Bytes, Dram:171675 Bytes
I (42590) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (42590) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (42590) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
W (43520) TONE_STREAM: No more data,ret:0 ,info.byte_pos:36018
I (43520) AUDIO_ELEMENT: IN-[IN_flash] AEL_IO_DON,0
I (43520) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (43590) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (43590) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (43590) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
I (44410) AUDIO_ELEMENT: IN-[DEC_mp3] AEL_IO_DONE,-2
I (44590) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (44590) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (44590) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
I (44610) MP3_DECODER: Closed
I (44610) ESP_AUDIO_TASK: Received last pos: 36018 bytes
I (44610) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (44720) AUDIO_ELEMENT: IN-[Audio_forge] AEL_IO_DONE,-2
I (44720) AUDIO_FORGE: audio forge closed
I (44720) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (45010) AUDIO_ELEMENT: IN-[OUT_iis] AEL_IO_DONE,-2
I (45230) ESP_AUDIO_TASK: Received last time: 3040 ms
I (45230) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (45240) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_FINISHED, 0, src:0, is_stopping:0
I (45250) ESP_AUDIO_TASK: Func:media_ctrl_task, Line:1030, MEM Total:4227975 Bytes, Inter:236863 Bytes, Dram:197851 Bytes
W (45260) ESP_AUDIO_TASK: Destroy the old pipeline, FINISHED
W (45270) ESP_AUDIO_TASK: The old pipeline destroyed, FINISHED
I (45590) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (45590) ESP_AUDIO_CTRL: Enter play procedure, src:0
I (45590) ESP_AUDIO_CTRL: Play procedure, URL is ok, src:0
I (45590) ESP_AUDIO_CTRL: Request_CMD_Queue CMD:0, Available:5, que:0x3ffc3ad4
I (45600) ESP_AUDIO_CTRL: Func:_ctrl_play, Line:775, MEM Total:4255507 Bytes, Inter:241331 Bytes, Dram:202319 Bytes
I (45610) ESP_AUDIO_TASK: It's a decoder
I (45620) ESP_AUDIO_TASK: 1.CUR IN:[IN_flash],CODEC:[DEC_mp3],RESAMPLE:[8000],OUT:[OUT_iis],rate:0,ch:0,pos:0
I (45630) ESP_AUDIO_TASK: 2.Handles,IN:0x3f804f14,CODEC:0x3f8050a4,FILTER:0x3f8144bc,OUT:0x3f805250
I (45640) AUDIO_PIPELINE: audio_pipeline_unlinked
W (45640) AUDIO_PIPELINE: There are no listener registered
I (45650) ESP_AUDIO_TASK: 2.2 Update all pipeline
I (45650) ESP_AUDIO_TASK: 2.3 Linked new pipeline
I (45660) AUDIO_PIPELINE: link el->rb, el:0x3f804f14, tag:IN_flash, rb:0x3f814aa8
I (45670) AUDIO_PIPELINE: link el->rb, el:0x3f8050a4, tag:DEC_mp3, rb:0x3f81480c
I (45680) AUDIO_PIPELINE: link el->rb, el:0x3f8144bc, tag:Audio_forge, rb:0x3f814848
I (45680) ESP_AUDIO_TASK: 3. Previous starting...
I (45690) AUDIO_ELEMENT: [IN_flash-0x3f804f14] Element task created
I (45700) AUDIO_ELEMENT: [IN_flash] AEL_MSG_CMD_RESUME,state:1
I (45700) TONE_PARTITION: tone partition format 0, total 21
I (45700) AUDIO_THREAD: The DEC_mp3 task allocate stack on external memory
I (45710) TONE_STREAM: Tone offset:00020c78, Tone length:36018, pos:8
I (45720) AUDIO_ELEMENT: [DEC_mp3-0x3f8050a4] Element task created
I (45730) AUDIO_ELEMENT: [DEC_mp3] AEL_MSG_CMD_RESUME,state:1
I (45740) MP3_DECODER: MP3 opened
I (45740) ESP_AUDIO_TASK: Blocking play until received AEL_MSG_CMD_REPORT_MUSIC_INFO
I (45750) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (45760) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (45850) ESP_AUDIO_TASK: Received muisc info then on play
I (45850) ESP_AUDIO_TASK: On event play, status:UNKNOWN, 0
I (45850) AUDIO_THREAD: The Audio_forge task allocate stack on external memory
I (45860) AUDIO_ELEMENT: [Audio_forge-0x3f8144bc] Element task created
I (45870) AUDIO_ELEMENT: [Audio_forge] AEL_MSG_CMD_RESUME,state:1
I (45870) AUDIO_FORGE: audio_forge opened
I (45870) AUDIO_THREAD: The OUT_iis task allocate stack on external memory
I (45880) AUDIO_ELEMENT: [OUT_iis-0x3f805250] Element task created
I (45890) AUDIO_ELEMENT: [OUT_iis] AEL_MSG_CMD_RESUME,state:1
I (45900) I2S_STREAM: AUDIO_STREAM_WRITER
I (45900) ESP_AUDIO_CTRL: Exit play procedure, ret:0
I (45910) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (45920) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (45930) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_RUNNING, 0, src:0, is_stopping:0
I (45940) ESP_AUDIO_TASK: Func:media_ctrl_task, Line:1030, MEM Total:3873263 Bytes, Inter:210687 Bytes, Dram:171675 Bytes
I (46610) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (46610) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (46610) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
W (47530) TONE_STREAM: No more data,ret:0 ,info.byte_pos:36018
I (47530) AUDIO_ELEMENT: IN-[IN_flash] AEL_IO_DONE,0
I (47530) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (47610) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (47610) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (47610) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
I (48040) VOIP_EXAMPLE: [ * ] [Play] input key event
I (48040) ESP_AUDIO_CTRL: Enter media_ctrl_stop procedure, src:0, type:0, st:RUNNING, phase:4
I (48050) ESP_AUDIO_CTRL: media_ctrl_stop, type:0, st:RUNNING, block_playing:1, MEDIA_CTRL_PHASE_WAIT_RUNNING
I (48060) ESP_AUDIO_CTRL: media_ctrl_stop, src:0, type:0, st:RUNNING, phase:4
I (48070) ESP_AUDIO_CTRL: Request_CMD_Queue CMD:2, Available:5, que:0x3ffc3ad4
I (48070) ESP_AUDIO_TASK: MEDIA_CTRL_EVT_STOP, status:RUNNING
E (48080) AUDIO_ELEMENT: [IN_flash] Element already stopped
W (4809 AUDIO_ELEMENT: OUT-[DEC_mp3] AEL_I_ABORT
W (48090) MP3_DECODER: output aborted -3
I (48100) MP3_DECODER: Closed
W (48100) AUDIO_ELEMENT: OUT-[Audio_forge] AEL_IO_ABORT
I (48110) AUDIO_FORGE: audio forge closed
I (48200) ESP_AUDIO_TASK: MEDIA_CTRL_EVT_STOP Done, dat:0
I (48200) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
I (48210) ESP_AUDIO_TASK: Received last pos: 29600 bytes
I (48210) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
I (48220) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
I (48230) ESP_AUDIO_TASK: Received last time: 2112 ms
I (48240) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
I (48250) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_STOPPED, 0, src:0, is_stopping:1
I (48260) ESP_AUDIO_TASK: Func:media_ctrl_task, Line:1030, MEM Total:4227975 Bytes, Inter:236863 Bytes, Dram:197851 Bytes
W (48270) ESP_AUDIO_TASK: Destroy the old pipeline, STOPPED
W (48280) ESP_AUDIO_TASK: The old pipeline destroyed, STOPPED
I (48290) ESP_AUDIO_TASK: Release the seeking process due to stopping
I (48290) ESP_AUDIO_CTRL: Exit media_ctrl_stop procedure, ret:0
I (48290) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
I (48310) SIP: [1970-01-01/00:00:23]=======WRITE 0603 bytes>>
I (48320) SIP:
SIP/2.0 200 OK
To: <sip:1001@192.168.2.99:64152;transport=TCP>;tag=1794862698
Content-Length: 155
v=0
s=Z
t=0 0
m=audio 34200 RTP/AVP 8 101
I (48370) SIP: [1970-01-01/00:00:23]=======================>>
I (48680) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (48680) ESP_AUDIO_CTRL: Enter play procedure, src:0
I (48680) ESP_AUDIO_CTRL: Play procedure, URL is ok, src:0
I (48680) ESP_AUDIO_CTRL: Request_CMD_Queue CMD:0, Available:5, que:0x3ffc3ad4
I (48690) ESP_AUDIO_CTRL: Func:_ctrl_play, Line:775, MEM Total:4255507 Bytes, Inter:241331 Bytes, Dram:202319 Bytes
I (48700) ESP_AUDIO_TASK: It's a decoder
I (48710) ESP_AUDIO_TASK: 1.CUR IN:[IN_flash],CODEC:[DEC_mp3],RESAMPLE:[8000],OUT:[OUT_iis],rate:0,ch:0,pos:0
I (48720) ESP_AUDIO_TASK: 2.Handles,IN:0x3f804f14,CODEC:0x3f8050a4,FILTER:0x3f8144bc,OUT:0x3f805250
W (48730) AUDIO_PIPELINE: Without stop, st:1
W (48730) AUDIO_PIPELINE: Without wait stop, st:1
I (48740) AUDIO_PIPELINE: audio_pipeline_unlinked
W (48740) AUDIO_PIPELINE: There are no listener registered
I (48750) ESP_AUDIO_TASK: 2.2 Update all pipeline
I (48750) ESP_AUDIO_TASK: 2.3 Linked new pipeline
I (48760) AUDIO_PIPELINE: link el->rb, el:0x3f804f14, tag:IN_flash, rb:0x3f814aa8
I (48770) AUDIO_PIPELINE: link el->rb, el:0x3f8050a4, tag:DEC_mp3, rb:0x3f81480c
I (48780) AUDIO_PIPELINE: link el->rb, el:0x3f8144bc, tag:Audio_forge, rb:0x3f814848
I (48780) ESP_AUDIO_TASK: 3. Previous starting...
I (48790) AUDIO_ELEMENT: [IN_flash-0x3f804f14] Element task created
I (48800) AUDIO_ELEMENT: [IN_flash] AEL_MSG_CMD_RESUME,state:1
I (48800) TONE_PARTITION: tone partition format 0, total 21
I (48800) AUDIO_THREAD: The DEC_mp3 task allocate stack on external memory
I (48810) TONE_STREAM: Tone offset:00020c78, Tone length:36018, pos:8
I (48820) AUDIO_ELEMENT: [DEC_mp3-0x3f8050a4] Element task created
I (48830) AUDIO_ELEMENT: [DEC_mp3] AEL_MSG_CMD_RESUME,state:1
I (48840) MP3_DECODER: MP3 opened
I (48840) ESP_AUDIO_TASK: Blocking play until received AEL_MSG_CMD_REPORT_MUSIC_INFO
I (48850) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (48860) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (48950) ESP_AUDIO_TASK: Received muisc info then on play
I (48950) ESP_AUDIO_TASK: On event play, status:UNKNOWN, 0
I (48950) AUDIO_THREAD: The Audio_forge task allocate stack on external memory
I (48960) AUDIO_ELEMENT: [Audio_forge-0x3f8144bc] Element task created
I (48960) AUDIO_ELEMENT: [Audio_forge] AEL_MSG_CMD_RESUME,state:1
I (48970) AUDIO_FORGE: audio_forge opened
I (48970) AUDIO_THREAD: The OUT_iis task allocate stack on external memory
I (48980) AUDIO_ELEMENT: [OUT_iis-0x3f805250] Element task created
I (48990) AUIO_ELEMENT: [OUT_iis] AEL_MSG_CMD_RESUME,state:1
I (48990) I2S_STREAM: AUDIO_STREAM_WRITER
I (48990) ESP_AUDIO_CTRL: Exit play procedure, ret:0
I (49010) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (49020) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (49030) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_RUNNING, 0, src:0, is_stopping:0
I (49040) ESP_AUDIO_TASK: Func:media_ctrl_task, Line:1030, MEM Total:3873251 Bytes, Inter:210687 Bytes, Dram:171675 Bytes
I (49710) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (49710) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (49710) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
W (50640) TONE_STREAM: No more data,ret:0 ,info.byte_pos:36018
I (50640) AUDIO_ELEMENT: IN-[IN_flash] AEL_IO_DONE0
I (50640) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (50710) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (50710) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (50710) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
I (51530) AUDIO_ELEMENT: IN-[DEC_mp3] AEL_IO_DONE,-2
I (51710) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (51710) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (51710) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
I (51720) MP3_DECODER: Closed
I (51720) ESP_AUDIO_TASK: Received last pos: 36018 bytes
I (51720) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (51830) AUDIO_ELEMENT: IN-[Audio_forge] AEL_IO_DONE,-2
I (51830) AUDIO_FORGE: audio forge closed
I (51830) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (52120) AUDIO_ELEMENT: IN-[OUT_iis] AEL_IO_DONE,-2
I (52340) ESP_AUDIO_TASK: Received last time: 3040 ms
I (52340) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (52350) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_FINISHED, 0, src:0, is_stopping:0
I (52360) ESP_AUDIO_TASK: Func:media_ctrl_task, Line:1030, MEM Total:4227975 Bytes, Inter:236863 Bytes, Dram:197851 Bytes
W (52370) ESP_AUDIO_TASK: Destroy the old pipeline, FINISHED
W (52380) ESP_AUDIO_TASK: The old pipeline destroyed, FINISHED
I (52710) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (52710) ESP_AUDIO_CTRL: Enter play procedure, src:0
I (52710) ESP_AUDIO_CTRL: Play procedure, URL is ok, src:0
I (52710) ESP_AUDIO_CTRL: Request_CMD_Queue CMD:0, Available:5, que:0x3ffc3ad4
I (52720) ESP_AUDIO_CTRL: Func:_ctrl_play, Line:775, MEM Total:4255507 Bytes, Inter:241331 Bytes, Dram:202319 Bytes
I (52730) ESP_AUDIO_TASK: It's a decoder
I (52740) ESP_AUDIO_TASK: 1.CUR IN:[IN_flash],CODEC:[DEC_mp3],RESAMPLE:[8000],OUT:[OUT_iis],rate:0,ch:0,pos:0
I (52750) ESP_AUDIO_TASK: 2.Handles,IN:0x3f804f14,CODEC:0x3f8050a4,FILTER:0x3f8144bc,OUT:0x3f805250
I (52760) AUDIO_PIPELINE: audio_pipeline_unlinked
W (52760) AUDIO_PIPELINE: There are no listener registered
I (52770) ESP_AUDIO_TASK: 2.2 Update all pipeline
I (52770) ESP_AUDIO_TASK: 2.3 Linked new pipeline
I (52780) AUDIO_PIPELINE: link el->rb, el:0x3f804f14, tag:IN_flash, rb:0x3f814aa8
I (52790) AUDIO_PIPELINE: link el->rb, el:0x3f8050a4, tag:DEC_mp3, rb:0x3f81480c
I (52800) AUDIO_PIPELINE: link el->rb, el:0x3f8144bc, tag:Audio_forge, rb:0x3f814848
I (52800) ESP_AUDIO_TASK: 3. Previous starting...
I (52810) AUDIO_ELEMENT: [IN_flash-0x3f804f14] Element task created
I (52820) AUDIO_ELEMENT: [IN_flash] AEL_MSG_CMD_RESUME,state:1
I (52820) TONE_PARTITION: tone partition format 0, total 21
I (52830) TONE_STREAM: Tone offset:00020c78, Tone length:36018, pos:8
I (52820) AUDIO_THREAD: The DEC_mp3 task allocate stack on external memory
I (52840) AUDIO_ELEMENT: [DEC_mp3-0x3f8050a4] Element task created
I (52850) AUDIO_ELEMENT: [DEC_mp3] AEL_MSG_CMD_RESUME,state:1
I (52860) MP3_DECODER: MP3 opened
I (52860) ESP_AUDIO_TASK: Blocking play until received AEL_MSG_CMD_REPORT_MUSIC_INFO
I (52870) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (52880) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (52960) ESP_AUDIO_TASK: Received muisc info then on play
I (52960) ESP_AUDIO_TASK: On event play, status:UNKNOWN, 0
I (52970) AUDIO_THREAD: The Audio_forge task allocate stack on external memory
I (52970) AUDIO_ELEMENT: [Audio_forge-0x3f8144bc] Element task created
I (52980) AUDIO_ELEMENT: [Audio_forge] AEL_MSG_CMD_RESUME,state:1
I (52990) AUDIO_FORGE: audio_forge opened
I (52990) AUDIO_THREAD: The OUT_iis task allocate stack on external memory
I (53000) AUDIO_ELEMENT: [OUT_iis-0x3f805250] Element task created
I (53010) AUDIO_ELEMENT: [OUT_iis] AEL_MSG_CMD_RESUME,state:1
I (53010) I2S_STREAM: AUDIO_STREAM_WRITER
I (53010) ESP_AUDIO_CTRL: Exit play procedure, ret:0
I (53020) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (53030) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_RUNNING
I (53050) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_RUNNING, 0, src:0, is_stopping:0
I (53060) ESP_AUDIO_TASK: Func:media_ctrl_task, Line:1030, MEM Total:3873251 Bytes, Inter:210687 Bytes, Dram:171675 Bytes
I (53720) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (53720) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (53720) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
W (54650) TONE_STREAM: No more data,ret:0 ,info.byte_pos:36018
I (54650) AUDIO_ELEMENT: IN-[IN_flash] AEL_IO_DONE,0
I (54650) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (54720) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (54720) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (54720) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
I (55550) AUDIO_ELEMENT: IN-[DEC_mp3] AEL_IO_DONE,-2
I (55720) VOIP_EXAMPLE: ringing... RemotePhoneNum 1000
I (55720) ESP_AUDIO_CTRL: Enter play procedure, src:0
W (55720) ESP_AUDIO_CTRL: Pipeline is already running. Please stop it first.
I (55740) MP3_DECODER: Closed
I (55740) ESP_AUDIO_TASK: Received last pos: 36018 bytes
I (55740) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (55850) AUDIO_ELEMENT: IN-[Audio_forge] AEL_IO_DONE,-2
I (55850) AUDIO_FORGE: audio forge closed
I (55850) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
I (56130) AUDIO_ELEMENT: IN-[OUT_iis] AEL_IO_DONE,-2
I (56190) ESP_AUDIO_CTRL: Enter media_ctrl_stop procedure, src:0, type:0, st:RUNNING, phase:4
I (56190) ESP_AUDIOTRL: media_ctrl_stop, type:0, st:RUNNING, block_playng:1, MEDIA_CTRL_PHASE_WAIT_RUNNING
I (56190) ESP_AUDIO_CTRL: media_ctrl_stop, src:0, type:0, st:RUNNING,phase:4
I (56200) ESP_AUDIO_CTRL: Request_CMD_Queue CMD:2, Available:5, que:0x3ffc3ad4
I (56210) ESP_AUDIO_TASK: MEDIA_CTRL_EVT_STOP, status:RUNNING
E (56220) AUDIO_ELEMENT: [IN_flash] Element already stopped
E (56220) AUDIO_ELEMENT: [DEC_mp3] Element already stopped
E (56230) AUDIO_ELEMENT: [Audio_forge] Element already stopped
I (56360) ESP_AUDIO_TASK: MEDIA_CTRL_EVT_STOP Done, dat:0
I (56360) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
W (56370) AUDIO_PIPELINE: Check AEL STOPPED, pl:0x3f803db0, el:0x3f8050a4, tag: DEC_mp3, state:15, wanted:14
W (56380) AUDIO_PIPELINE: Check AEL STOPPED, pl:0x3f803db0, el:0x3f8144bc, tag: Audio_forge, state:15, wanted:14
I (56390) ESP_AUDIO_TASK: Recv Element[DEC_mp3-0x3f8050a4] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
W (56400) AUDIO_PIPELINE: Check AEL STOPPED, pl:0x3f803db0, el:0x3f8144bc, tag: Audio_forge, state:15, wanted:14
I (56410) ESP_AUDIO_TASK: Recv Element[Audio_forge-0x3f8144bc] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
I (56420) ESP_AUDIO_TASK: Received last time: 3040 ms
I (56430) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_FINISHED
W (56440) AUDIO_PIPELINE: Check AEL FINISHED, pl:0x3f803db0, el:0x3f804f14, tag: IN_flash, state:14, wanted:15
W (56450) AUDIO_PIPELINE: Check AEL FINISHED, pl:0x3f803db0, el:0x3f8050a4, tag: DEC_mp3, state:14, wanted:15
W (56460) AUDIO_PIPELINE: Check AEL FINISHED, pl:0x3f803db0, el:0x3f8144bc, tag: Audio_forge, state:14, wanted:15
I (56470) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_FINISHED, 0, src:0, is_stopping:1
I (56480) ESP_AUDIO_TASK: Func:media_ctrl_task, Line:1030, MEM Total:4227975 Bytes, Inter:236863 Bytes, Dram:197851 Bytes
W (56490) ESP_AUDIO_TASK: Destroy the old pipeline, FINISHED
W (56500) ESP_AUDIO_TASK: The old pipeline destroyed, FINISHED
I (56510) ESP_AUDIO_TASK: Release the seeking process due to stopping
I (56510) ESP_AUDIO_CTRL: Exit media_ctrl_stop procedure, ret:0
I (56510) ESP_AUDIO_TASK: Recv Element[OUT_iis-0x3f805250] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
I (56530) ESP_AUDIO_TASK: Recv Element[IN_flash-0x3f804f14] MSG,type:20000,cmd:8,len:4,status:AEL_STATUS_STATE_STOPPED
W (56620) SIP: Deny the call
W (56620) SIP: CHANGE STATE FROM 16, TO 2, :func: _sip_uas_process_res_invite:1007
I (56620) VOIP_EXAMPLE: SIP_EVENT_HANGUP
I (56620) SIP: [1970-01-01/00:00:27]=======WRITE 0421 bytes>>
I (56630) SIP:
SIP/2.0 486 Busy Here
To: <sip:1001@192.168.2.99:64152;transport=TCP>;tag=-59658848
Content-Length: 0
I (56670) SIP: [1970-01-01/00:00:27]=======================>>
I (56690) SIP: [1970-01-01/00:00:27]<<=====READ 0349 bytes==
I (56690) SIP:
ACK sip:1001@192.168.2.99:64152;transport=TCP SIP/2.0
Max-Forwards: 69
CSeq: 63409426 ACK
Content-Length: 0
I (56720) SIP: [1970-01-01/00:00:27]<<======================
Re: voip例程,按play键无法接听
Posted: Tue Feb 14, 2023 2:32 am
by dodo55
大家使用voip没有遇到我这样的问题的吗?
还是我的哪里出问题了?
现在想实现用两个板子对讲都没法调!啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊
Posted: Tue Feb 14, 2023 3:00 am
by dodo55
esp-adf更新到最新master版本问题依旧。
Posted: Tue Feb 14, 2023 11:44 am
by William
从日志来看的话,应该是 Freeswitch 没有回复 ACK 包导致的,请检查一下服务器日志。
ps. Freeswitch 请使用ubuntu版本,win版本会出现类似没有相应的情况出现。
ps2. 或者您换个客户端用 linphone 试试看
Posted: Wed Feb 15, 2023 10:52 am
by dodo55
已经解决,Freeswitch的锅,改用UDP连接才行。
