ESP32 : Reset loop
antonins
ESP32 : Reset loop
Postby antonins » Sun Feb 12, 2023 12:51 pm
Hello all,
I've got an issue with one of my ESP32 board.
After running several hours, the wifi disappear. When I have a look on serial activity, I've got this reset loop :
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0xff001cff,len:267327
1150 mmu set 00010000, pos 00010000
1150 mmu set 00020000, pos 00020000
1150 mmu set 00030000, pos 00030000
1150 mmu set 00040000, pos 00040000
ho 0 tail 11 room 5
load:0x018c0000,len:-699138048
ets Jul 29 2019 12:21:46
I try to download the program again, to flahs the ESP32 but still the same issue.
Do you know what could be the cause of this loop ?
Thanks for your feedback
antonins
Re: ESP32 : Reset loop // QOUT solve the issue ?
Postby antonins » Mon Feb 20, 2023 11:01 am
More information about this issue.
I find that if the flash upload in QOUT mode ESP32 WROOM works perfectly. If I reupload the program with DIO, reset loop occur again.
I've got several board with this issue.
Anyone have an idea of what happen ?
Thanks for your help,
Antonin
Postby Sprite » Tue Feb 21, 2023 12:49 am
What specific board hardware is this? If it's custom, do you have schematics / board layout files?
antonins
Postby antonins » Fri Feb 24, 2023 6:58 am
Hello ESP-SPRITE,
my ESP32 board is a ESP32-WROOM-32E-N8
I have several IC working well with this esp32, but IC with the new program have this issue.
If I removed ESP32 from the IC and sold a new one with an old program, everything works fine.
Users browsing this forum: Google [Bot], meta-externalagent and 6 guests
