(The code simply read the variable before, and after the ULP to check if the variable has changed.)
C code
Assembly code
I can't read anything on these screen shootsI tried to change any global variable with ULP, but doesnt work. What I do wrong?
Thanks for reply krz!. I know about "ulp_" variables, and yes, I using this and doenst work... I think is anything about load or store, but need help...Hi urbanze,
I can't read anything on these screen shootsI tried to change any global variable with ULP, but doesnt work. What I do wrong?I will be guessing then
Maybe you are missing the "ulp_" prefix?
Ref. https://esp-idf.readthedocs.io/en/lates ... -variables
EDIT: If this is not the case, then try a classic example https://github.com/espressif/esp-idf/tr ... system/ulp.
This example is using global variables and it works for me.
I can view the screen shots but not the tiny fontWhy you cant view screen shots?
.global xULP code seems to be missing a store after the increment.
I can view the screen shots but not the tiny fontWhy you cant view screen shots?![]()
Copy and paste of code would work better for me in this case.
Also a plan text is easier for anybody to copy back for testing instead of retyping.
@ESP_igrr, thank you for help with this one!
How do verify whether "ulp_x" is changing its value or not?Code in C have:
variable: extern uint32_t ulp_x = 1;
and load/run to ulp.
Should be e.g.:
Code in ulp
.global x
x: .long 0
.global entry
entry:
move r0, x
ld r0, r0, x
add r0, r0, 1
halt
I comment before with another two tests, and anyone doenst worked
void ulp()
Serial.printf("\nULP_X: %d", ulp_x & UINT16_MAX);
delay(100);
ulp_load_binary(0, ulp_main_bin_start, (ulp_main_bin_end - ulp_main_bin_start) / sizeof(uint32_t));
ulp_run((&ulp_entry - RTC_SLOW_MEM) / sizeof(uint32_t));
delay(100);
}Users browsing this forum: No registered users and 2 guests
