VSCode JTAG debugging in macOs error
Posted: Sat Feb 25, 2023 5:24 am
Hello, I am trying to debug a project in VSCode, I am using the Wrover Kit v4.1, this on macOs, this is what I am doing:
Opening OpenOCD with:
And startup debug in vscode: I get the following on OpenOCD console:
And in VSCode it gets stuck on
ANd I can't step in or run, my launch.json is:
Any suggestions? What am I missing?
openocd -f board/esp32-wrover-kit-3.3v.cfgCode: Select all
Open On-Chip Debugger v0.11.0-esp32-20221026 (2022-10-26-14:48)
Licensed under GNU GPL v2
For bug reports, read
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : starting gdb server for esp32.cpu0 on 3333
Info : [esp32.cpu0] Target halted, PC=0x400D9687, debug_reason=00000001
Info : [esp32.cpu0] Reset cause (3) - (Software core reset)
Info : Set GDB target to 'esp32.cpu0'
Info : [esp32.cpu1] Target halted, PC=0x40112852, debug_reason=00000000
Info : [esp32.cpu1] Reset cause (14) - (CPU1 reset by CPU0)Code: Select all
Info : accepting 'gdb' connectionon tcp/3333
Info : [esp32.cpu0] Target halted, PC=0x40092612, debug_reason=00000001
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 116 KB
Info : Flash mapping 1: 0x30020 -> 0x400d0020, 277 KB
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.irom' size 280 KB
Info : Using flash bank 'esp32.cpu0.drom' size 120 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
Info : [esp32.cpu0] requesting target halt and executing a soft reset
Info : [esp32.cpu0] Debug controller was reset.
Info : [esp32.cpu0] Core was reset.
Info : [esp32.cpu0] Target halted, PC=0x500000CF, debug_reason=00000000
Info : [esp32.cpu1] requesting target halt and executing a soft reset
Info : [esp32.cpu0] Target halted, PC=0x40000400, debug_reason=00000000
Info : [esp32.cpu1] Debug controller was reset.
Info : [esp32.cpu1] Core was reset.
Info : [esp32.cpu1] Target halted, PC=0x40000400, debug_reason=00000000
Warn : [esp32.cpu0] Failed reading 32 bytes at address 0x40115230
static void heap_bubble_down(int index)
while (index < TAG_CACHE_SIZE / 2) {
int left_index = index * 2 + 1;
int right_index = left_index + 1;
int next = (s_log_cache[left_index].generation < s_log_cache[right_index].generation) ? left_index : right_index;
heap_swap(index, next);
index = next;
}Code: Select all
"name": "ESP32 OpenOCD",
"type": "cppdbg",
"request": "launch",
"cwd": "${workspaceFolder}/build",
"program": "${workspaceFolder}/build/hello_opencv.elf",
"miDebuggerPath": "/Users/dariovazquez/.espressif/tools/xtensa-esp-elf-gdb/11.2_20220823/xtensa-esp-elf-gdb/bin/xtensa-esp32-elf-gdb",
"targetArchitecture": "arm64",
"setupCommands": [
{ "text" : "target extended-remote :3333"},
{ "text" : "set remote hardware-watchpoint-limit 2"},
{ "text" : "monitor reset halt"},
{ "text" : "flushregs"}
