SPI slave mode (example)
rahmaevao
Postby rahmaevao » Fri Oct 06, 2017 9:58 am
Friends, I'm trying to start slaving the SIP mode.
the master gives a good premise (see fig.)
I'll use the code from the example:
#include <stdio.h>
#include <stdint.h>
#include <stddef.h>
#include <string.h>
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "freertos/queue.h"
#include "lwip/sockets.h"
#include "lwip/dns.h"
#include "lwip/netdb.h"
#include "lwip/igmp.h"
#include "esp_wifi.h"
#include "esp_system.h"
#include "esp_event.h"
#include "esp_event_loop.h"
#include "nvs_flash.h"
#include "soc/rtc_cntl_reg.h"
#include "rom/cache.h"
#include "driver/spi_slave.h"
#include "esp_log.h"
#include "esp_spi_flash.h"
#define GPIO_MOSI 12
#define GPIO_MISO 13
#define GPIO_SCLK 15
#define GPIO_CS 14
//Main application
void app_main()
    //Configuration for the SPI bus
    spi_bus_config_t buscfg={
        .mosi_io_num=GPIO_MOSI,
        .miso_io_num=GPIO_MISO,
        .sclk_io_num=GPIO_SCLK
    //Configuration for the SPI slave interface
    spi_slave_interface_config_t slvcfg={
        .mode=0,
        .spics_io_num=GPIO_CS,
        .queue_size=3,
        .flags=0,
    //Enable pull-ups on SPI lines so we don't detect rogue pulses when no master is connected.
    gpio_set_pull_mode(GPIO_MOSI, GPIO_PULLUP_ONLY);
    gpio_set_pull_mode(GPIO_SCLK, GPIO_PULLUP_ONLY);
    gpio_set_pull_mode(GPIO_CS, GPIO_PULLUP_ONLY);
    //Initialize SPI slave interface
	spi_slave_initialize(VSPI_HOST, &buscfg, &slvcfg, 1);
    char recvbuf[129]="";
    memset(recvbuf, 0, 33);
    spi_slave_transaction_t t;
    memset(&t, 0, sizeof(t));
    while(1) {
        //Clear receive buffer, set send buffer to something sane
		memset(recvbuf, 0x34, 129);
        //Set up a transaction of 128 bytes to send/receive
        t.length=128*8;
        t.rx_buffer=recvbuf;
		spi_slave_transmit(VSPI_HOST, &t, portMAX_DELAY);
		printf("Received: %s\n", recvbuf);
But in the terminal I see only the meaning of the recvbuf (see fig)
D is defined beforehand as 0x34 (in ASCII it is a "4") the help of a cmd memset
How to read the accepted parcel?
I very sad.
Help me :(
rahmaevao
Re: SPI slave mode (example)
Postby rahmaevao » Mon Oct 09, 2017 6:04 am
I read to "ESP32 Technical Reference Manual"what resiving data saved id SPI_W0_REG ~ SPI_W15_REG.
Can I read registers from esp-idf? :roll:
How i can it do?
Postby Sprite » Mon Oct 09, 2017 7:07 am
SPI slave at the moment uses DMA if I recall correctly, so no need to read the DMA stuff. We do have the restriction that the length of the transaction (t.length) should be exactly the amount of bits transferred; if not, the DMA engine can get confused and less than the expected amount of bits can be written. We're working on lifting this restriction in a newer version of the slave driver.
rahmaevao
Postby rahmaevao » Mon Oct 09, 2017 8:04 am
Thanks for the answer, but I did not understand how to use the SLAVE MODE.
The master mode is very good.
The buffer length is the same for the master and for the slave.
Also, I can not get by sending data from the slave to the master through the MISO line. (I check with an oscilloscope)
I fill in the
    char sendbuf[3]="";
    char recvbuf[3]="";
    sendbuf[0]=0x31;
    sendbuf[1]=0x32;
    sendbuf[2]=0x33;
    recvbuf[0]=0;
    recvbuf[1]=0;
    recvbuf[2]=0;
    t.length=3*8;
    t.tx_buffer=sendbuf;
.tx_bufer.
But there is no dispatch.
there is neither otvpravki nor reception. What should I do?
Thanks for the answer)
rahmaevao
Postby rahmaevao » Mon Oct 09, 2017 8:12 am
How use DMA?
Simple past
heap_caps_malloc(3, MALLOC_CAP_DMA);
in my code?
AAAwen
Postby AAAwen » Mon Oct 09, 2017 8:19 am
Dear Friends,
I used the same sample of spi-slave. I make the M3 module(as master) send 128 bytes to esp32(as slave). But, it doesn't work. Can you help me? Thanks!
我用git上的sample程序调试spi slave功能,但是接收数据存在问题。我用M3做主端发送128字节的数据到esp32,和楼主一样打印出来的接收内容是默认值。请问如何解决这个问题?谢谢!
rahmaevao
Postby rahmaevao » Mon Oct 09, 2017 9:42 am
You can provide a working example?
rahmaevao
Postby rahmaevao » Mon Oct 09, 2017 11:58 am
Y
I restructure my code.
char *POINTER_T = heap_caps_malloc(3, MALLOC_CAP_DMA);
    char *POINTER_R = heap_caps_malloc(3, MALLOC_CAP_DMA);
    while(1) {
		t.length=3*8;
		t.tx_buffer=POINTER_T;
		t.rx_buffer=POINTER_R;
		spi_slave_transmit(HSPI_HOST, &t, portMAX_DELAY);
		printf("%d",*POINTER_R);
		printf("\n");
But nothing happens. It is accepted what is "248".
Help me please.
LakshmiDhanaraj
Postby LakshmiDhanaraj » Tue Oct 24, 2017 10:36 am
I am using the SPI slaver driver example,sender as master and receiver as slave.I can able to transmit/receive data without dma.But it restricts the number of bytes to 32.For transmitting more than 32bytes,I am enabling the dma to 1,won't receive/transmits the data.Please help me out to solve this issue.What I have to change in the code for transmitting more than 32 bytes?
AAAwen
Postby AAAwen » Thu Oct 26, 2017 1:16 am
Dear All,
Is Anybody solve this issue? Who can help me? :cry:
Thx.
关于SPI从端的示例遇到的问题是否有大神已经解决了?谢谢。
Users browsing this forum: ChatGPT-User, Google [Bot] and 6 guests
