Problems with Pthread.h. ESP32-DevKitC-V4
javioreja
Postby javioreja » Fri Mar 03, 2023 1:18 pm
I'm trying to program an ESP32 DevKitC-V4 board with the Pthread.h library in Arduino IDE 1.8.19 and I got an error. Trying to narrow down the error, I loaded an example code with the same library and still got the same error:
#include <pthread.h>
void *printThreadId(void *threadid) {
   Serial.println((int)threadid);
   pthread_t threads[4];
   int returnValue;
   for( int i = 0; i< 4; i++ ) {
      returnValue = pthread_create(&threads[i], NULL, printThreadId, (void *)i);
      if (returnValue) {
         Serial.println("An error has occurred");
void loop() {}
When I look at the serial monitor y see this error:
Guru Meditation Error: Core 0 panic'ed (IllegalInstruction). Do you have any idea what the problem might be?
Re: Problems with Pthread.h. ESP32-DevKitC-V4
Postby Sprite » Sat Mar 04, 2023 12:04 am
Not sure if pthreads work the same as FreeRTOS tasks, but if they do, it's not valid to have a thread function return. If this is indeed the issue, you should have the thread delete itself first via pthread_exit.
Users browsing this forum: Baidu [Spider], ChatGPT-User and 2 guests
