JL1101 Etheret PHY
whcir@charter.net
JL1101 Etheret PHY
Postby whcir@charter.net » Mon Mar 06, 2023 5:46 pm
I found the driver for the JL1101 ethernet here https://github.com/dtlzp/relay_dev_demo ... ts/esp_eth. It is for the ESP32 IDF environment, how can this be made as an Arduino library so it can be used in the Arduino IDE?
Minatel
Re: JL1101 Etheret PHY
Postby Minatel » Tue Mar 07, 2023 11:25 am
This will be possible if you add this driver to the Arduino via the Library Builder.
In sum, the ESP-IDF used on Arduino ESP32 core should be recompiled in order to add this new driver. Using it as an Arduino library will not be possible in this case.
Users browsing this forum: Bing [Bot], ChatGPT-User and 2 guests
