Basic question about HTTP audio element
Posted: Wed Mar 08, 2023 10:56 am
I have a fresh install of ESP-IDF and ESP-ADF on Ubuntu 22.04.
IDF is version 4.4.4 and ADF is Github master.
The complete toolchain builds and I am able to flash and run some IDF and ADF examples. However, I am encountering a problem with the ADF.
The relevant messages are as follows:
I read this issue https://github.com/espressif/esp-va-sdk/issues/180 and unchecked in menuconfig.
I also read this issue https://github.com/espressif/esp-adf/issues/856 and checked and , but still receive the same errors.
Side question, is it necessary to rebuild 1500+ files for every change in menuconfig or is idf.py build the wrong call after making changes?
pipeline_bt_source exampleThe relevant messages are as follows:
E (15158) esp-tls: couldn't get hostname for :dl.espressif.com: getaddrinfo() returns 202, addrinfo=0x0
E (15158) esp-tls: Failed to open new connection
E (15158) TRANSPORT_BASE: Failed to open a new connection
E (15168) HTTP_CLIENT: Connection failed, sock < 0
E (15168) HTTP_STREAM: Failed to open http stream
Enable mbedtls time supportI also read this issue https://github.com/espressif/esp-adf/issues/856 and checked
Allow potentially insecure optionsCode: Select all
Skip server certificate verification by defaultSide question, is it necessary to rebuild 1500+ files for every change in menuconfig or is idf.py build the wrong call after making changes?
