TaskHandle_t, and passing object causing crash when using object
uneasy
Postby uneasy » Thu Mar 09, 2023 7:23 pm
It's probably user error, but I can't figure out how to properly pass created object to task, so it can be used along with other tasks.
Here is bit of code when I am creating a task and passing an object
LinHandler lin;
TaskHandle_t Task1;
void loop2(void* parameter) {
    LinHandler& lin = *((LinHandler*)parameter);
    for (;;) {
        lin.write();  // Write data to LIN
        delay(100);
  // Initialize your task (2nd loop)
    xTaskCreatePinnedToCore(
        loop2,        // name of the task function
        "ledCheck",   // name of the task
        1000,         // memory assigned for the task
        (void*)&lin,  // parameter to pass if any
        1,            // priority of task, starting from 0(Highestpriority) *IMPORTANT*( if set to 1 and there is no activity in your 2nd loop, it will reset the esp32)
        &Task1,       // Reference name of taskHandle variable
        0);
Outside task, `lin.write()` works just fine, but when it's inside the task, it crashed esp on execution. So My assumption is I am not actually passing proper reference ?
And just for reference, inside my object that's how I initialize it
private:
 lin_bus _lin = lin_bus(LIN_SERIAL, LIN_V2, LIN_EN, LIN_WK, LIN_TX);
and `_lin.write` is what's causing the crash.
What I am doing wrong ?
Re: TaskHandle_t, and passing object causing crash when using object
Postby Sprite » Fri Mar 10, 2023 1:03 am
Just to check, after the task initialized, you *only* do things with the lin object within that task? If not, the issue may be that that driver isn't properly re-entrant.
boarchuz
Postby boarchuz » Fri Mar 10, 2023 9:04 am
1000 bytes is a very low stack size. Try 4096.
Side note: The comment on priority is wrong (0 is lowest)
Users browsing this forum: Baidu [Spider], Bytespider and 2 guests
